pics. of my progress on my 3.3 conversion
pics. of my progress on my 3.3 conversion - 05.11.2009, 06:26 PM
Just a few pics. I have all of the electronics for it, just haven't had the time to make a bracket for the rx yet or solder things together...
I painted the springs and the chassis. After all of the brackets are made and the drilling, etc is done I am going to repaint it. Also remove the color from the AL tubes and the 17mm hexes
Metallover
RC-Monster Spudgunner
Metallover's Avatar
05.11.2009, 07:00 PM
That's purrty.
05.11.2009, 07:03 PM
I like to be different...hence the orange theme
ANGRY-ALIEN
ANGRY-ALIEN's Avatar
05.11.2009, 07:11 PM
Wow. that's real nice... The orange and black combo works well together.
05.11.2009, 07:21 PM
Of all the conversions I'd seen, none were orange/black
ANGRY-ALIEN
05.11.2009, 07:27 PM
Yep, you truly have a unique build there... can't wait to see the finished product. Are you sticking with the same colour scheme for the bodywork?
Alien
05.11.2009, 07:31 PM
Alien
Yup, RUSTY XL-5 from here on RCM is painting a body for me. He will hopefully incorporate a little black and white into the scheme, but that is up to him...
Metallover
Metallover's Avatar
05.11.2009, 07:37 PM
I like orange - http://www.spudfiles.com/forums/chri...ct-t12820.html
05.11.2009, 07:51 PM
Another w/great taste!
mopar1994
mopar1994's Avatar
05.12.2009, 04:04 PM
that orange chassis looks really good! did you just srpay paint it? im curious, what brand of hub carriers are those?
05.12.2009, 06:49 PM
Thanks! I am going to repaint it when the truck is totally done....I put the paint on to thick so it is peeling off in some areas and I also did not use the correct type of primer. ( I need an etched primer )...it is high temp motor paint called Plastic Cote.
The hub-carriers are RD Racing
ANGRY-ALIEN
05.12.2009, 07:08 PM
I think you will have to sand down the primer with 150 - 220 grit to give the paint a good surface to stick to. Then apply the coats lightly.
Alien
05.12.2009, 10:53 PM
Very nice!
RCShocker
RC Monster
05.13.2009, 01:59 PM
Holy Smokes thats nice!!!!
Glad I wandered into the Revo section.
05.13.2009, 04:29 PM
Alien
Nothing a sandblaster can't handle to strip the paint completely and then hopefully a etched primer will help the paint stick a little better.
I am thinking of cutting off completely the old engine mount support to make a new mount for the battery tray. I mocked up the battery tray last night on the side where the old nitro motor used to be and I am not to found of the battery being up at an angle if using the existing old motor mount support...if something were to happen, the batt. would slide into the spur gear so....I am rethinking the mounting design for that side. Also, I am going to make a bracket for the rx that sits above the steering servo similar to Mike's design on his crt.5 kit.
