need an eagletree to buy or borrow -
05.30.2009, 05:20 PM
like it says, I need a datalogger, and I'll buy it from you, or, I'd like to borrow it. I'd replace it if I broke it of course. If you got one, email, PM, or respond to this thread..............
Does it need to be an eagletree, and what exactly do you want to measure? I have a sentry pro from novak with all the sensors and software I could lend you in about a week or two.
E-revo MMM 2200 6s zippy 50MPH of pure fun and parts destroying powa!
Futaba 3pk more controller then anyone person needs
TC5 top speed drifter 21mph on crappacks and 40 on calc
doesn't need to be an eagletree; I didn't know there were others! I just really want to see my amp draw, and voltage info. that's about it, anything more is just icing on the cake. I believe the novak system does that stuff. How hard is it to hook up?
Its easy I've got the voltage and amp sensors made up for with traxxas connectors, its pretty simple, just pull the esc connector from the rx plug into one of the top 3 in plugs on the mod, use an extension connector to plug into the slot just next to where you hooked up the esc, and run the ext to the rx, plug the volt and amp sens where they are labled making sure all connectors have the black (-) on the outter edge, turn on ur truck or car press the button on the logger and go, when your done just discconnect the batters and hook it to the pc open the software and click download and it'll give data on everything you connected, it comes with 6 digital temp sens, volt, amp, g-force, rpm (for sensored or non sensored) throttle or sterring position sens via the rx, and 1 analog loop temp sens.
