Originally Posted by RcZoNe444
I’m relatively new to electric (& this forum). I was into nitro for several years and got an E-Maxx one day and loved it and now I can’t stand my nitro’s at all any more. I am in the process converting my entire fleet of nitro’s to electrics and selling off what I don’t want to convert.
Welcome to RC-Monster! Another one who has caught the electric bug!
I have basic charging down but I would like to know the best way to charge NiMH and Li-po. I know that you don’t want to charge over one C for a Li-po but would this mean that you could charge an 8000mAh battery at 8 amps? That seams high to me. My LHS owner says he dose not charge any Li-po’s over 1 amp to be on the safe side.
When charging Lipos, the easiest way to determine the charge rate is to get the capacity, divide by 1000, then multiply by the manufacturer's recommended charge rating (the 'C' part - this is usually 1C, so stick with that to be on the safe side).
Example 1
Battery 8000mAh, max charge 1C
8000/1000 = 8
8 * 1 = 8A
Example 2
Battery 2500mAh, max charge 3C
2500/1000 = 2.5
2.5 * 3 = 7.5A
And what is the recommended charging rate for NiMH batteries too?
Nickel based batteries can be charged at about 2-3 C safely, but watch the temperatures the first few times, don't let them get too hot.
The charger I use is a Duratrax ICE if that helps. Any and all information is appreciated.
I don't have experience with that particular charger, but they all work using the same principles as above. Just make sure the charge settings are correct, and you should have no problems.
