Originally Posted by suicideneil
Copyright infringement- you'd need to alter the design 15% to avoid it.
The length is the same as the stock item though, so if you have the the truck to measure (or ask a fellow member with a ruler), it would be easy to replicate. Only issue is you'd need to buy the GorillaMaxx upper plates and posts to mate them to the chassis plate; next best option is to make something along the lines of the FLM chassis perhaps...
its only infringement if I sell it, and besideds, its a diffrent alloy, difrent thickness, and I'll probably make a few more changes as I go...
I have acces to a full metal shop, CNC equipment, etc...
I was thinking of buying the posts anyway, or mabey the lunsford ones...
