Can a "Stampede Super Chassis" conversion be used to convert a Rustler
Old No. 1
Old No. 1's Avatar
Question Can a "Stampede Super Chassis" conversion be used to convert a Rustler - 02.08.2006, 10:50 PM
Just wondering if anyone has used the Stampede Super Chassis Conversion Kit to "hop up" their Rustler. I already ordered it so I hope it works out. They REALLY NEED to make a COMPLETE RUSTLER CONVERSION KIT .... not just a Stampede version. The price difference is why I'm pressing my luck with the "wrong" conversion kit. OH, this is an electric Rustler. NOT A NITRO. Thanks for your input.
boss 302
02.08.2006, 10:56 PM
rusty's and pedes share a lot of the same parts but i dont know how it will work out but im pretty sure you can make it work.
MetalMan
MetalMan's Avatar
02.09.2006, 12:03 AM
You turn the Rustler into a 'Pede by adding the 'Pede chassis, since the servo mounting changes, and chassis braces are needed.
Old No. 1
Old No. 1's Avatar
02.09.2006, 11:53 PM
Is the Chassis Brace kit an absolute necessity ? or just for show ?
MetalMan
MetalMan's Avatar
02.10.2006, 12:00 AM
The chassis braces do just what they are called - they give (necessary) support to the chassis.
skellyo
skellyo's Avatar
02.10.2006, 12:02 AM
I would say they are necessary (whether you go with stock plastic braces or the FLM braces). Without them you only have two screws on each end holding things together.
Old No. 1
Old No. 1's Avatar
02.10.2006, 12:21 AM
I guess I planned on getting them anyway, as well as the tranny case and diff assembly.
Growing old doesn't have to be boring. :025:
skellyo
skellyo's Avatar
02.10.2006, 12:29 AM
I just received my diff and tranny case today...very nice parts.
Old No. 1
Old No. 1's Avatar
02.10.2006, 12:34 AM
I'm just hoping I don't get stuck with a modification problem due to the servo mounting position changing. Guess I will find out soon enough. We have one local hobby shop here and it sucks. It's all model trains and rockets and the such. Might have to go to Home Depot for "mod" parts, ahaha. sad.
MaxxFusion
MaxxFusion's Avatar
02.10.2006, 08:15 AM
The servo shouldnt be a problem. I had a Hitec 645 in my Pede that I took out to put in my Rusty.
  Send a message via MSN to MaxxFusion
skellyo
skellyo's Avatar
02.10.2006, 09:39 AM
Did you buy the FLM arms also? If so and you didn't have an extended front conversion done before, you'll end up needing longer steering turnbuckles and camber links. I used a pair of Lunsford Punisher 2 1/2" turmbuckles with long Traxxas rod ends from a # 1942 set of ends for camber and I'm planning on trying out 96mm turnbuckles from a non-widemaxx E-maxx for steering. I just need my new servo saver in before I can verify they'll fit. The rear will be the standard camber links, unless you bought the extended length arms.
Old No. 1
Old No. 1's Avatar
02.10.2006, 11:34 PM
Yeah, I got the arms. I bought the whole conversion kit. -Super Stampede Chassis.
-Your Choice of Arms. You can stick with the stock arms or go with the wider arms for a wider stance to improve handling.
-Adjustable Front Bulkhead
-Rear Shock Tower
-Front Shock Tower
-Bulk Brace
-Battery Straps
-Turnbuckles
-All Mounting Hardware Included
.... and I ordered the Chassis Brace Kit ... I chose the regular length arms instead of the extended ones.
skellyo
skellyo's Avatar
02.11.2006, 12:07 AM
-Rear Shock Tower
-Front Shock Tower
-Bulk Brace
-Battery Straps
-Turnbuckles
I have the whole chassis kit too. FYI, it does not come with turnbuckles unless you purchase the extended length arms. The front regular length FLM A-Arms are wider than a standard stampede A-Arm, so you will need new turnbuckles for the front camber and steering. I hope to have some pics of mine up tomorrow or Sunday if I can get it rolling. And then hopefully next weekend, it'll be ready to run since Mike got in the BK controllers. And get ready...once you see the plastic tranny on the aluminum chassis, you'll be reaching for your wallet to break out the CC and order the FLM tranny case and the steel diff gear Mike offers.
Old No. 1
Old No. 1's Avatar
02.11.2006, 12:28 AM
I sure hope the kit comes with the turnbuckles or else that'd be false advertising.
skellyo
skellyo's Avatar
02.11.2006, 01:06 AM
I just e-mailed Mike about it. Either the description is wrong, or they got left out of my kit.
