1515 1y chinese cc neu motor vrs real american made neu motor
Rivermaxx
1515 1y chinese cc neu motor vrs real american made neu motor - 07.08.2009, 02:52 PM
This has probably been touched on but is there a difference in power output between the 2. I know there is some diferences on how they are built but is one motor considerably better made or better materials than the other or last longer or possibly more efficient. I am getting one or the other for my silverback build but not sure which one yet. If I get a new traxxas one off ebay I wonder if it would still be under warranty.
scarletboa
scarletboa's Avatar
07.08.2009, 02:56 PM
there is only a slight amount of difference between the two, but not enough to offset the cost difference.
just get the cc neu.
Kcaz25
Kcaz25's Avatar
07.08.2009, 03:11 PM
Courtesy of Mark (mkrusedc):
Originally Posted by mkrusedc
The 1500 series has power ranges from 150 watts to over 4,000 watts. The maximum rpm is 60,000. The can diameter is 1.53” smooth and 1.73’ for the finned can. The motors have 12 slot stators and 4 pole rotors. The shaft diameter is 5 mm and is 0.75” long. The motors weigh about 10-12 oz depending on type.
The first two numbers of a Neu motor designate the diameter. For example the 1500 series has a 15mm rotor.
The second two numbers denotes the rotor length. For example xx09, xx12, and xx15. Larger numbers means a longer rotor. A longer rotor generates more torque.
The third two numbers usually are the number of turns. For example 1.5, 1, and 2.5 The higher number the more turns.
The next letter d/y is the coil configuration: d = delta or triangle. y = wye or star.
A d coil configuration is a motor that has 1.73 times higher kv and 1.73 times less torque than a y motor configuration with the same turns. For example a 1515/1d has 4100kv and a 1515/1y has 2200kv. A motor with windings in delta configuration gives low torque at low rpm, but can give higher top rpm. Wye configuration gives high torque at low rpm, but not as high top rpm.
The last letter f/s is the type of can: f = finned. s = smooth can
http://www.neumotors.com/20061222/1500_series_.html
Castle Neu
-Casing closed (the new NEU has a closed case)
-Kevlar wrapped magnets Not carbon inside as the "real" Neu
-Wires comes out on the side, not in the back
-The motor shaft has a flat spot
-5x16x5mm Bearings Japan (Koyo or NMB - CNC grade, 100K RPM rated)
-Laminations M19 non-oriented magnetic steel Japan
-Magnets Same as Neu – China N38UH magnet
-Shaft material Stainless - USA
-Case T6061 – China
-US source 10 gauge silicone insulated wire
-60,000 rpm up to 200F
The Tekno RC Edition Neu Motors feature:
Larger 5x13x4mm bearings front and back
Sealed motor can
Rear end bell is safely secured by Neu's latest design
Flat spot along length of shaft
07.08.2009, 09:14 PM
I'd go for the castle Neu aswell- the power output difference & efficiency varience is minor at best, barely noticeable during normal use.
Kcaz25
Kcaz25's Avatar
07.08.2009, 09:35 PM
Yeah my vote is for the CC Neu considering the price difference and the fact that the CC Neu is alittle better suited to ground use.
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
07.08.2009, 09:49 PM
I don't know why Neu hasn't made geniune Neu's that are terrain specific like the CC models. CC just has to come out with a 1500 - 1700Kv. unit for 5-6s lipo. IMO, they should never have had the 2650Kv... kinda useless for most of us, even buggies.
jhautz
jhautz's Avatar
07.08.2009, 10:48 PM
+1 Dont know what CC is waiting for. They are missing the boat IMO.
to make it...
or break it...
Silent...But Deadly
DwightSchrute
I'm obsessed with The Office
DwightSchrute's Avatar
i've got 2 neu 1515 1y's and 2 castle neu 2200's and i can say categorically the 1515 1y's run a good 20 degrees cooler on a consistant basis. the power/speed is identical imo
8IGHT 2.0 2650KV MMP
LOSI TEN SCTE NOVAK 3700 MMP
B44 MMP TRINITY D3 6T
B4 MMP TRINITY D3 9.5
E-REVO BRUSHLESS EDITION
zeropointbug
Z-Pinch racer
07.08.2009, 11:01 PM
DwightSchrute, good point. This should be noted by everyone, that just a few point in efficiency percentile will make a drastic difference in running temperatures... even though they have seemingly the same power.
Rivermaxx
07.08.2009, 11:33 PM
Isnt that because of the internal fans. Which the cc dont have
mkrusedc
NeuMaxx
mkrusedc's Avatar
07.08.2009, 11:43 PM
My "reaL" neu has always run cool. I do not think it has an internal fan.
http://www.rc-monster.com/forum/show...9&postcount=51
nitrostarter
nitrostarter's Avatar
07.09.2009, 12:10 AM
No internal fans...
N. Rustler conversion
Kcaz25
Kcaz25's Avatar
07.09.2009, 12:30 AM
Its because they are open that they run that 20 degrees cooler.
mkrusedc
NeuMaxx
mkrusedc's Avatar
07.09.2009, 12:48 AM
That is quite possible.
nitrostarter
07.09.2009, 01:21 AM
I dont believe that. My Neu is in a Tekno motor mount with a rear endbell cover. Its sealed up and I noticed the change in temps on the same setup.
