Does anyone know of a wing mount that will directly bolt on the FLM towers? Tower are on the way and I was hoping shock mounting holes might do the trick.
PS. I've got the old style gorillamaxx towers, and although I havn't tried it, 4 of the shock mounting holes line up almost in the exact same way as the Dace holes for the wing mount. As for the FLM towers, I doubt you'll be able to get a tower attached to it...
I was thinking of mounting a wing as well. I think mike is supposed to get some dace towers in. So you can get them and mount a muegen wing mount right to it.
Peace!
Country
Help support the
Rc-Monster Buy here
That's cool. My FLM's are already on the way so I will probably mod something up.
have you thought of trying the stock chassis to see if that gets rid of the problem? something might be grounding out on it or something.
Interesting idea. I put two layers of shrink under anything that was in contact with the chassis, but I just may have to try it. Only problem is I think both controllers are gone. I know one leg on a cap of the 12020 is gone.
Did you feel resistance as the screw was almost fully in (before it was actually all the way on)? If you have a Dremel, you could shorten them a millimeter or two.
Good question, I just did a test and they are not too long.
If you have a stock mount and a clamp probably not. It may be close though. If you look thru the hole of the motor where the screw goes does it look like it has contacted the winding.
Peace!
Country
Help support the
Rc-Monster Buy here
