The ISC Ultimate Speed Run 2009
Nic Case
Fast RC-Monster
Nic Case's Avatar
The ISC Ultimate Speed Run 2009 - 07.31.2009, 09:43 AM
Sign-up time for the Ultimate Speed Run is here!
***How Fast is you R/C Car or Truck? ***
Come find out, with a dual optical speed trap & optimized conditions.
It will be held at the Auto Club Dragway Nov 14th & 15th. 2009
Entries will be limited to 60 - so acting quickly is advised.
The Biggest– most highly publicized Radio Controlled Speed Run ever!
Compete for Top Speed World Records – in the 12 separate ISC classes.
This Straight-Line Event will be 2 days of exciting action.
Bring It!
N
http://www.rc-isc.com/
07.31.2009, 09:57 AM
Can we send you a car to run?
Nic Case
Fast RC-Monster
Nic Case's Avatar
07.31.2009, 10:08 AM
I'm flattered.
What do you have? What's in it?
But if you have a car or truck to send (and you cant get there yourself)
I'm sure we can find a qualified individual to run it....LOL
I forgot to mention -- anyone that makes a pass over 100 mph will receive a 100 mph club hat !
Cheers
N
nitrostarter
nitrostarter's Avatar
07.31.2009, 10:18 AM
Well I'm planning over 150mph, do I get a special hat too?
Glad to see you here Nic, and good luck at the event. Lets see some outrageous numbers again!
N. Rustler conversion
aqwut
Brushless Heavy Weight....
aqwut's Avatar
07.31.2009, 10:42 AM
Man you guys are lucky down there... I wish we had something like that in Canada.... California is so far away... darn it..
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
hoober
08.01.2009, 11:10 AM
If you make 150 , you get 1.5 hats.
Electric stock (2wd and 4wd) rule is pretty clear (I think) with a single 2S pack , but for electric mod can the pack be made with 4S of 2P cells?
The voltage max seems clear that it is intended to guard against overcharge, but there is a rule that is stating max of "4 cells" , my proposed set-up is technically 8 cells.
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
08.01.2009, 12:06 PM
^^^ I guess you'll have to run in the "Electric Open" class. IMO putting two packs in series OR parallel makes them 1 pack. So putting two 4s packs in series (although separate packs) would count as an 8s pack.
hoober
08.01.2009, 12:28 PM
That's not quite what I meant. Here's:
2 small 2200 mah cells soldered permanently together in parallel to make one 4400 cell.
Make a 4S pack out of these 2P 4400 cells, technically there are 8 cell , but still falls within the max votage and max series rule. Really no difference in performance than a pair of 4S packs in parallel.
What's_nitro?
08.01.2009, 12:34 PM
Oh, you meant 8 cells as in the "number of cells in the car". Not necessarily "the number of cells in the battery" (?). Should be fine then.
Nic Case
Fast RC-Monster
Nic Case's Avatar
08.07.2009, 11:11 PM
Whatcha got?
Nitrostarter
thanks for the warm welcome
– wow 150 --that’s the spirit!
If you (or anyone) needs some help, I'll do what I can to pointcha in the right direction
Aqwut
Yes we are a bit lucky (California is the place you otta be...)
Hoober & What’s Nitro
You guys got the intent right – just bring it out and go fast!
There's a class for just about every car made..
Check out the sign-up list ---> http://www.rc-isc.com/forums/showthread.php?t=266
N
08.07.2009, 11:16 PM
Nic - I was contemplating something but actually going v slow now and going to the world rock crawling champs instead lol...
Not sure I can so slow and fast this year - I'll see when I get back but was thinking about a super mod CRT.5...
I'll see if mikes interested in helping...
What's_nitro?
08.08.2009, 10:35 PM
I see there isn't a class for non wheel-driven vehicles....
Nic Case
Fast RC-Monster
Nic Case's Avatar
08.21.2009, 10:19 AM
Things are heating up......
http://rc-isc.com/forums/showthread.php?t=266
How fast do you think you can go?
N
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
08.21.2009, 11:52 AM
Anxious to see you beat your record Nic, Good Luck !
Nic Case
Fast RC-Monster
Nic Case's Avatar
08.21.2009, 12:22 PM
Thanks!
I'm not even sure if I can break it.......
Conditions have to be juust right.
N
