Are the Stock E Revo and Slayer diffs the same?
sikeston34m
Are the Stock E Revo and Slayer diffs the same? -
08.27.2009, 09:55 PM
Like the Title says:
Are they the same?
sikeston34m
Find all posts by sikeston34m
2
nitrostarter
08.27.2009, 10:03 PM
Erevo has part number 5382X and 3978 in the center to hold the spider gears more secure while the Slayer spiders are a simple pin setup.
Here are pics:
REVO
SLAYER
N. Rustler conversion
10:09 PM
nitrostarter
Find all posts by nitrostarter
3
sikeston34m
08.27.2009, 10:21 PM
VERY Good eye for detail! Thank you.
My first set of Stock E Revo diffs lasted 50 or 60 packs at least. Life wasn't easy on them either.
A Tooth broke off the rear pinion and the gears began chewing the floating particles up.
I wonder if the Slayer Diff would be relatively as tough?
Hmmm..... Different cup too
10:22 PM
sikeston34m
4
nitrostarter
08.27.2009, 10:38 PM
Well they added the I-bar to the newer E-Revo's to beef them up to handle the BL power better. Adding the I-bar thus changed the design of the cup.
The Slayer diffs are slightly weaker in design but will hold their own to some mild to strong BL setups.
nitrostarter
Linear Mode
Switch to Threaded Mode
