NeuMaxx
All kinds of gears even custom gears. -
09.03.2007, 11:27 PM
I don't know if this has ever been posted but I was having trouble finding certain pinions and I found this site:
http://www.sdp-si.com/
If they don't have what you need than you can have any gear made to your specs.
I have never used them but the BattleBots guys do.
09.04.2007, 12:11 AM
I ordered two gears from them. I did not have them custom made, so i did not get 5mm bore, but very close, It can be drilled ot to 5mm. Gears seem to be made well, worked out to about 15 per gear with s/h.
09.04.2007, 01:06 AM
I got 3 gears from them all 5mm. I got a 22, 24 and 30T aluminum ones. They are tough and the only thing I changed was the set screw. I drilled and tapped holes for 3mm set screws.
NeuMaxx
09.04.2007, 09:52 AM
Thanks for the feedback.
08.26.2009, 12:45 PM
Cool! I think I found what I need. Thanks Edit: maybe not the shaft diameter is too big. What is acetayl? is it like delrin . Acetal with brass insert I wonder if it will hold up as a pinion. This is all I could find in stock. I need a mod 1 28 tooth pinion.
08.26.2009, 01:37 PM
We use them a lot for little drive componets, then I found out where they get their pullies made so we use them now. SDPSI is great but expensive. We use a 15 tooth .080" pitch drive pulley and a 30 tooth for our conveyor. Boring the pulley to fit a 5mm shaft is easy, but make sure you use a drill bit that MEASURES .196",most are undersized or over sized, even metric drills are this way so watch out.
Jeff
Brushless Heavy Weight....
08.26.2009, 09:08 PM
it's very expensive for shipping to Canada... UPS is the only method, and be ready to pay $20+ per $10 gear...
09.04.2009, 11:45 AM
Just made an order there.. They now have USPS shipping to Canada... AWESOME!!!.. I'll update to let you guys know how it turns out...
09.04.2009, 11:54 AM
Specifics on the order?
09.04.2009, 01:56 PM
Ordered 4x 8mm bore 24T Mod 1 Pinions with 20mm hub diameter and 8 or 10mm face width... came up to about $70 something...
09.04.2009, 05:14 PM
 Unlike the old Gears, these have big set screws... and I'm glad I had chosen the 20mm face.. Very nice gears, and fits perfectly.. I will definately get some More.. Ordered it on Monday, got it today in the mail. no customs charges.. 1st class mail... SWEET!!!!
09.04.2009, 05:33 PM
WOW they look really beefy!!!
Soldermaster Extraordinaire
09.04.2009, 06:25 PM
I have ordered many things from Sdp-Si. Nothing custom yet, but I love the quality of their stuff so I'll use them when I need something custom.
Yes- I believe they are, in fact, made of beef.
09.04.2009, 06:44 PM
that must be some super lean beef then... The shipping option for USPS is great, before UPS use to charge insane brokerage fees.... I mean, brokerage cost more than the product..
