Go Back   RC-Monster Forums > Support Forums > Team Tekin
Thank you tekin
brushlessboy16
brushlessboy16's Avatar
Thank you tekin - 09.29.2009, 07:49 AM
Sent my Rx8 in for a warranty repair, was in the facility for 2 days and shipped back priority.
Great service- just dont hope I have to use it again
Metallover
RC-Monster Spudgunner
Metallover's Avatar
09.29.2009, 08:43 AM
Do you store your stuff inside in a cool, dry place or out in the garage? Maybe that is a reason some of your escs failed... Don't see how you can have such bad luck.
And I wouldn't expect service that fast. Thats amazing.
phildogg
phildogg's Avatar
09.29.2009, 08:54 AM
That was fast service.
phil
Slash 4x4 163mph
drc rail 150 mph
phildogg6@yahoo.com
my youtube channel
brushlessboy16
09.29.2009, 11:47 AM
phil
Negative, sealed workshop..
the rx8 failed because of a faulty lower PCB- seems to be a few failing like that- dont think this one was my fault.
danhfvcsd
09.29.2009, 04:34 PM
What happens when this problem arises? Mine just turned off as if the power wires (or something power related) were unplugged... There is something loose inside the bottom of my esc, and i was able to press on the bottom of the esc, and it'd boot up again...
Similar to yours or something else? I'm gonna send mine in when i get back from bali - have a working trip to make for a couple days...
brushlessboy16
09.29.2009, 06:56 PM
Mine acted like it was working fine- But none of the control board's signals were being sent to the power board.
Leds, BEC, temp sensor all worked.
danhfvcsd
09.29.2009, 07:40 PM
hmmm - waiting for someone to have the same thing i did - no one yet -lol-
BrushlessRacer
09.30.2009, 07:16 AM
Same problems here! 1 completly dead sent in a month ago, not back yet. 2nd unit has the same probs as "danhfvcsd" descripes.
What I did: opened the case (unsolder wires first) after that I cleaned it well with a soft brush. I put some extra foam inside to press both boards firmly together. Closed the case, en no problems again for a long while.
Now the problems are back after a few heats racing. I'm going to open it again and have a look.
I will take some pictures to show you guys.
Hope this week my spare ESC will return then the 2nd will go for a trip to USA
TekinTeamMgr
TekinTeamMgr's Avatar
09.30.2009, 04:09 PM
Both of those units that are shutting off need to be sent in for proper diagnosis and repair.
  Send a message via Yahoo to TekinTeamMgr
