Eight-T 1.0
bcltoys
Eight-T 1.0 - 10.04.2009, 06:45 PM
Is there a known problem with hinge pins bending the lower rear on the batt side is the one in ?.Bent it once put a new one in and bent again don't know if it's happening when jumping and landing it just seems to happen.Could it be the batt weight.Or maybe i need to up my shock oil weight and springs.
jacobsjo87
10.04.2009, 10:37 PM
Yes, the rear outer hinge pins on the 8ight are known to be a weak spot. Some people upgrade to Associated 1.02 shock shafts and use them to replace the hinge pins. The 8ight 2.0 has bigger pins
EDIT: I'm 98% sure these are them http://www.amainhobbies.com/product_...hock-Shaft-102
bcltoys
10.05.2009, 05:39 PM
Will the 50 tooth spur from the 2.0 fit the 1.0 diff.
GO-RIDE.com
10.05.2009, 08:24 PM
If it's the outer rear hinge pin, then yes they bend easy. You can upgrade to the 2.0 hinge pin by drilling out the holes in your existing arms.
E-8ight - Tekin RX8 2000kv/4S
Beanie
10.06.2009, 09:35 AM
Most people (me included!) swap them out for the mugen pins that are way better....part number:
mugen e0124
No mods required....
GO-RIDE.com
10.06.2009, 02:31 PM
mugen e0124
What's the OD of the mugen pins?
Beanie
10.06.2009, 02:35 PM
Not sure, same as the original Losi 8T 1.0 pins for definite though.......
