http://www.maxamps.com/proddetail.ph...8-Pack&cat=218
MaxAmps.com presents the ultimate 1/8-scale hard case racing pack. As you racers know, the most important factor for your batteries is voltage under load. This LiPo pack boasts a 60C rating for all your amp hungry racing setups. It will maintain higher voltage under load than any other LiPo battery pack on the market. Plus, you'll have no problem getting plenty of run time with 5250mah of capacity.
Perfect fit for any 1/8 scale electric vehicle that runs a single 4S pack including the Losi 8ight-E, Associated RC8-E, SC8-E and more!
- Hard Outer Case
- 5250mah Capacity
- 14.8 Volts
- 47mm X 139mm X 39mm
- 60C - 4660 surge watts(315 amps)
- 504 grams
- Water-sealed for all-weather protection
- Comes standard with Hyperion taps
- Comes standard with 12awg Deans Ultra wire
- Highest performance in the industry
- Twice the capacity of NiMH for the same weight
- Plug and Play for any charger/balancer/vehicle
- We add the connectors and balancing taps for you
- Money Back Guarantee
- Normally ships within 24-48 hours
- Exceeds safety standards of the IATA
- Built today with factory fresh cells
- Can be recharged unlimited times per day
- Copper Tab Cells for lower resistance
This should be interesting.
