suggestions for power supply for hyperion? -
11.24.2009, 12:45 PM
ok guys
I just got the new Hyperion Dual III and need to know what size power supply I need to be able to charge 15 amps thru both outputs at the same time. I'm guessing 35-40 amp power supply?
What is the max power rating of both channels combined? Also, what is the max voltage it will take? Some of the higher output chargers will take voltages much higher to help reduce required current.
Running on EXACTLY 12V, you'll need 37.5A (180W per port (so 360 total), divided by 0.8, divided by 12). 40A would be preferable to account for power supply capacitors aging over time.
In the beginning the Universe was created.
This has made a lot of people very angry and has been widely regarded as a bad move.
