Wiring for a BK120
mpetrich
Wiring for a BK120 - 03.09.2006, 07:31 AM
I did search, but I did not find exactly what I was looking for. I am wiring my BK120 and it has two black/two red wires on the battery side of the ESC. Do the two blacks just get wired together on one side of the Deans connector? Then same with the reds and that would complete the male side of the Deans?
There are six wires on the motor side of the ESC. I am assuming two wires for each of the three motor phases. So, two of the ESC wires need to get connected to one of three motor wires? And then so on until I am done.
Thanks for the help and clarification.
Matt
Sponsored by Fusion Batteries
Associated RC10T4
Associated TC4
HB Lightning Pro II Converted
Dafni
Dafni's Avatar
03.09.2006, 07:44 AM
Yes, you are right. Just treat the double wires as if they were one.
mpetrich
03.09.2006, 12:13 PM
Thank you for the help.
Matt
Associated RC10T4
Associated TC4
Cartwheels
03.09.2006, 02:22 PM
Would I be correct in assuming that if I wanted to parallel two battery packs I would just need to put a deans connector on each set of red & black wires? Then plug into the two seperate packs.
coolhandcountry
coolhandcountry's Avatar
03.09.2006, 03:19 PM
That would work indeed.
damon
03.12.2006, 08:35 AM
I am sorry for jumping in on the string, but I am a new guy waiting for the 8xl to get in. I have the 12020. Can I ask a question so I set it up right. The two black wires go on the negative of one deans connector, the two red go on the positive on another deans connector. Do I then run a wire between the + to + and - to - of the two connectors? Will deans battery wire work? Any one with a picture? Thanks!
coolhandcountry
03.12.2006, 09:03 AM
you run the jumper wire from the negative to the postive of the other dean.
There are some pics around here for it
Superemaxx89
03.12.2006, 12:41 PM
Once someone has completly wired their 12020 (or other doubled up wire controller) can you post a picture? Thanks.
brijar
Knowing You're Hooked on RC: Priceless...
brijar's Avatar
03.12.2006, 01:13 PM
Here is what I think it should look like:
Hope this helps!
Brijar!!!
REVO 3.3 Conversion: 3906 trans, CC 1518, MMM, 6s Gens Ace 5k 40C, LST Diffs, Summit shafts
Slash 2x4 LCG
Two Slash 4x4s
Rustler
Superemaxx89
03.12.2006, 01:32 PM
wow. that is a good drawing!
brijar
brijar's Avatar
03.12.2006, 06:08 PM
Thank you:018:. Took me about 30 - 40 minutes to make:025:. I don't even have a 12020 controller, just a 9920 with only 1 set of wires, so I based it off what I've heard about it as well as off my own controller.
Thanx again,
Brijar!!!
Slash 2x4 LCG
Two Slash 4x4s
Rustler
damon
03.12.2006, 06:25 PM
Wow! Awesome picture Brijar! Thansk for the work....that is crystal clear!
Would you all use deans battery wire for the jumper?
brijar
brijar's Avatar
03.12.2006, 06:38 PM
Yes, W.S. Deans Wire is very nice and an excellent choice. If you have to use wire for anythin RC related, use Deans wire unless it is small wire such as receiver wires and servo wires.
Brijar!!!
Slash 2x4 LCG
Two Slash 4x4s
Rustler
Romster
03.14.2006, 08:31 PM
Kool keep this drawing UP It would help alot of people.. Thanks It helps me too.
thanks Brijar... :)
coolhandcountry
03.14.2006, 09:00 PM
There was a pic on the forum. I want to say it was posted by papa. It showed where the black jumper was.
