so here is my set up on my twinforce i built for my GF to drive when we go out bashing, i am wondering if i can get away with useing a MMP instead of an MMM.
im not going to lie, its a big heavy truck, but is set up to go slow and it will have about 60-70% punch control and medium start power
fully loaded and ready to run it 12.286 lbs and is geared for 32mph
here's the facts from brians calculator
Differential Ratio: 3.3076923076923075
Transmission Ratio: 2.36
Other Ratio: 1
Spur Tooth Count: 50
Pinion Tooth Count: 25
Total Voltage: 14.8
Motor KV: 1650
Tire Diameter (inches): 7
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor Coil Resistance: 0.01
Spur/Pinion Ratio: 2 : 1
Total Ratio: 15.61231 : 1
Tire Circumference (inches): 21.99 inches (558.58 mm)
Rollout: 1.41:1
Total Motor Speed: 24420 RPM
Vehicle Speed: 32.57 mph (52.32 km/h)
Effective KV Value: 1650
KT constant: 0.82 oz-in/A
Time to Get to Top Speed: 4sec
Usable Output Power: 343.39 watts (0.46 HP)
Input Power Required: 538.66 watts (0.72 HP)
Input Current Required: 36.4 amps
Motor Torque: 0.16 ft-lbs
Axle Torque: 2.47 ft-lbs
Average Acceleration: 3.58 inches/sec
Acceleration Force: 19.93 meters/sec^2
Acceleration Gs: 0.36 G
Required Motor RPM: 23990 rpm
Required Motor KV: 1621
KT constant: 0.83 oz-in/A
here are the batterys - 2 5200mah 30c packs for 14.8v
http://www.hobbyking.com/hobbyking/s...dProduct=10277
so judge and jurry, is the mmp going to be ok, or do i need to use a MMM?
