HoBao 17mm Big Bores
simplechamp
simplechamp's Avatar
HoBao 17mm Big Bores - 05.03.2010, 11:33 AM
Anyone else run these? I know Bondo does... I just got a set in today for my Jammin X1. Pictures don't do these babies justice, they are massive! And I don't think you can find a better deal for a set of big bores.
Looking for some setup tips. I'm pretty much going to be bashing, maybe a little track time, but no serious racing. Use stock blue spring or white or grey? Use oil that was included (300wt, but I'm guessing it's 300cs?) or different? Bondo told me to get the alloy caps, so I'll need to order those and maybe another set of springs next time cash allows.
Thanks for any help!
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
05.03.2010, 12:08 PM
Hobao 300wt is 30wt in our speak.
On the Hyper 9E buggy the front caps are out in the open, aluminum will obvisously prove to be much more durable. The plastic caps didn't leak, I was just afraid to break them on a ugly landing so I went with and suggested aluminums.
I have Losi 8ight buggy shocks on my 4x4 Slashy and I like the shocks on my 9E better.
Blue is the softest, then White and Grey .
alport
05.03.2010, 12:29 PM
I use them on my hyper8 pro and they are great. Bondonutz is right the oil is 30wt..
simplechamp
05.04.2010, 10:16 AM
Well I don't think that 30wt is going to cut it, did you guys use it? Probably going to try 45wt front and 40wt rear to start.
jzemaxx
05.04.2010, 03:16 PM
What are the shock lengths eye to eye???
Serpent S811-E Tekin
Revo 3.3 BL- 1515 1Y
Mugen MBX6 NEU/MMM
Mugen MBX6-T NEU/MMM
Losi LST2.0 MT NEU/MMM
Losi 8T RTR 2.0 NEU/MMM
Losi 8T 2.0 NEU/MMM
Losi 8B-E 2.0 NEU/MMM
simplechamp
05.04.2010, 05:49 PM
107mm Front
127mm Rear
simplechamp
05.07.2010, 07:36 PM
Built the shocks last night. Used 45wt in the front and 40wt in the rear. Those little snap rings are a PITA, first thing I did today was order a proper snap ring tool so the next time I have to rebuild it should be a lot easier. The soft blue springs seem pretty firm actually, and I didn't need to preload them very much, which I was pleased with. Unfortunately still got a bit of work to do before the X1 is up and running, but should get to try it out pretty soon and see how the shocks perform.
simplechamp
05.08.2010, 09:25 PM
Here's the big bores mounted on my X1. The lengths were just about the same as the stock shocks, but I needed to do a few things to get them to fit. The spots where the lower ends mount had to be shaved a little bit to allow the larger captured balls to fit. Also I needed to add a small spacer on the front shock standoff so the spring and upper a-arm had enough clearance. I'm starting to think now I should have maybe used the stock 30wt oil, but I'll have to see after I get the buggy running.
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
05.09.2010, 09:40 AM
Looks good, one thing tho ?
Whats going to keep the top of the shock from popping off the mount ?
simplechamp
05.09.2010, 10:32 AM
The rear are held on with a nut and washer. The front standoff screws didn't stick out long enough because of the extra spacer I had to use, so that is just a temp setup until I get longer screws. Or I might just switch to using two shorter screws, one into each side of the standoff.
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
05.09.2010, 11:24 AM
OK, Just checking. Wanted to make sure you knew there might be problem w/it as is.
