Originally Posted by suicideneil
When I setup my dx6i, I plugged in the bind plug, connected up an rx pack ( no esc connected or anything ), then held the bind switch on the tx and turned the tx on. It took two attempts, but on the 2nd go I got the rx bound to the tx and its been fine since. You might just need to try an rx pack to power the rx, rather than using an esc to supply power. Once its bound you can remove the bind plug.
Thx I did wat u told me n it bind but the telementry system is not working with my telementry spm 1305( combo telementry system)
do I need to bind that too?
The temp sensor was reading 999degree.
