what thickness would i need?
rcbeast
what thickness would i need? - 12.11.2010, 09:55 PM
i found some cheap carbon fiber... and i want to make some parts for my emaxx and some other stuff... what would be the recomended thickness for stuff like shocktowers and maybe even chassis????
Imo
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
Imo - 12.12.2010, 12:15 AM
For shock towers, probably 4-5mm is good. For a chassis it depends if you want to do a single plate or a double-deck thing. For a plate chassis I'd use at least 4mm. If you went with the double-deck then 2.5-4mm would work depending on the design and your intended use.
DrKnow65
DrKnow65's Avatar
12.12.2010, 02:34 AM
Be cautious that some of the thicker CF around is actually a laminate with a foam center and a fiberglass backing.... Not all of it is, but just be aware.
12.12.2010, 04:42 AM
I just made a 5b wing with some of that stuff. It's weird to work with.
Cody.McP
12.12.2010, 05:04 AM
I agree with What's Nitro?, 4-5mm would be good for both pieces.
