shock set-up ideas
furryninjas
shock set-up ideas - 04.21.2006, 03:38 PM
ok, getting closer to completion..... FLM/GPM stampede
but before i start building the shocks, what should i use....... here's what i got at hand without running to the store....
GPM shock w/ rezzies, feel like standard weight springs, 2 hole pistons.....
1 / 2 / 3 hole pistons to choose from (stock Traxxas, may need slight sanding to fit), (instead of messing those up, might just stick with the 2 hole pistons that came with GPM shocks)
and
30 / 45 / 60 wt. Trinity shock oils
suggestions on best set-up for front and rear, keep 'em the same, or different since i got the option? mostly bashing, maybe some racing....
squeeforever
squeeforever's Avatar
04.21.2006, 05:52 PM
depending on the weight i would say 30 or 40ish.
