Hello,
I need help from someone who has seen both the LST1 and LST2 steering knuckles.
I am searching for aluminium ones for a while, and came across these:
http://www.hot-racing.com/index.cgi?...=LST2108;c=160
They say they are for the LST LST2 and Aftershock, but that is not possible because of the difference between the LST's.
LiquidRC advertises them as for the LST and Aftershock, and the outer hole looks a bit to small for an 8mm axle and a bearing?
But the part number suggests it is for the LST2?
I do not think it will fit, but just to make sure, can someone help me out?
I have not seen the LST1 knuckles good enough to see the difference, but I do know that the holes in the GPM LST2 knuckles look bigger on the picture?
Thanks in advance!
Ruud
