04.03.2013, 03:55 PM
I just finished tricking out a 2wd one for a friend of mine's son. Here is what I did..
FLM Extended chassis
ST Racing Concepts Heat Treated Polished Steel Lock Nut Style Hinge Pin Set (Black)
RPM73612 RPM Hybrid Gearbox Housing & Rear Mounts (Black)
Losi Ten T shocks all around
LOSB2907 Losi Shock Standoff Set (4)
RPM80372 RPM Front Bearing Carrier Set
TRA3632A Traxxas L/R Aluminim Caster Blocks 30 Deg (Blue)
SPTST3654-12GM ST Racing Concepts 12mm Aluminum "Clamp Style" Wheel Hex Set (Gun Metal) (4)
SPTST3639GM ST Racing Concepts 6mm Heavy Duty Front Shock Tower (Gun Metal)
ST Racing Concepts 6mm Heavy Duty Rear Shock Tower (Gun Metal)
I tried to make it bomb proof...I also added Proline tires. I am sure I am forgetting a few misc. items. Hope this helps
