Brushless setup for a e-zilla10?? -
07.21.2006, 05:43 AM
HI !
I,d like to kwo what brushless setup that woud be sutiable for a hotbodies ezilla10 ? i whant a top speed of at least 45mph:027: and over 25min runtime on a 8000mah lipo pack with 4-6s.
and then i,d like to know what kind off uppgrades i have to do on my ezilla10 t? to handle the power .
The maxx halfshafts fit the e-zilla and will be needed also make sure the grub screw that attaches the half shafts to the diffs isnt to tight as it tends to beak the diffs
also the shocks are abit of a pain the 3 racing ones are better but still not brill make sure you change the screws in the bottom of the shock to some longer ones or they come out and bend the shafts
i ran a 9L in my e zillait was ok but i only used 12 nimh cells with lipo i could see it breaking more often i defently wouldnt runt more than 4s lipo in an e zilla
What's gonna break if i run more than 4s lipos ? is it something in the driveline ore did you just meen that it woud go so fast that i might hit something ?
Right :018: so you guy's think that i choud buy a savage to convert instead of the e-zilla10 ? witch one ? savage 25,save x or ???
and what brushless setup woud be perfect for a savage ? can i use the stock transmission ? and coud i mont he motor under on top of thr spurgear ?
i quessthat i coud lock the 2-speed cluth by inserting a long skrew instead of the small set skrew and sprin rigt ? and maybe put som epoxy between the cluch and the second gear ?
The traxxas revo seems easyer to convert ? what do you think ?i already have a e-maxx transmission.
I am in the process of adding a HV-Maxx to the Zilla. May I ask what size of pinion do you use? Did you follow the gear ratio recommended by Novak (13/66 or 14/66)? Thanks.
