Tranny gears
GorillaMaxx360
GorillaMaxx360's Avatar
Tranny gears - 10.05.2006, 08:58 PM
I was wondering I am getting a brushless set up with the gorillamaxx and the one speed conversion. What gears do I need to get metal and what brands and where do I find them. What kind of slipper clutch shoud I get and where can I buy it.
sjcrss
Hyper 7 Erevo Center Diff
sjcrss's Avatar
10.05.2006, 09:55 PM
try the search feature and it will answer most of your questions....
but.....for the single speed, you should be fine with the rcmonster idler gear...also the rr slipper is good, but hte strobe is the best, the only thing is..they are discontinued and are real hard to find...try looking on ebay for those....
Bl E-REVO
Quark 125b
Castle Creations-Neu 2200kv motor
((2s2p)(4s)
7800mah 7.4v Lipo Pack
E-Revo 1/8 scale Hyper 7 CD
http://www.rc-monster.com/forum/show...1&goto=newpost
  Send a message via MSN to sjcrss
Serum
Serum's Avatar
10.06.2006, 01:57 AM
The single speed conversion makes the stock output gear last longer, because the stock 2 speed has got some play to make the shifting go easy. The entire drivetrain gets weaker because of it.
with the singlespeed conversion you remove the slop from the transmission.
and with the steel idler that Mike has you are able to make a very tough transmission.
If you want your transmission to last;
the top inputshaft (the one that holds the 2 gears) needs some modification as well. The gear is connected with the shaft thru a pin. this pin is known to fail. You need to replace that hollow pin with a solid one. (i used a hardened nail)
About the slipper;
the rrp slipper can hold the ofna 51t spur, you only need to tweak the spur a little.
