Where are all you gear covers -
10.19.2006, 11:39 AM
How come when you guys take pictures of your E-Revos. They don't seem to have gear covers on them? It seems like they would get chewed up in short order without them.
10.19.2006, 11:53 AM
No need for them..
Gearmesh is best checked with the covers off.. :p
10.19.2006, 12:18 PM
Originally Posted by Serum
No need for them..
Serum takes the open shot........................:005:
10.19.2006, 01:52 PM
I assume you mean the Revos that use the Emaxx tranny? I ran my V1 Revo without the cover for quite a while and never had a chewed up spur due to debris.
The stock Revo tranny doesn't have a gear cover option. Seems to work OK.
RC-Monster TQ
10.19.2006, 02:56 PM
I would be more concerned with electrical wires get snagged by the gears than debris damage.
Just don't stick your fingers down there when you're runnnig your truck :027:
Ha Ha
10.19.2006, 03:07 PM
I dont have mine on 'cause it doesnt fit. Pinion Hits and the RRP slipper set up hits.
10.19.2006, 04:59 PM
I don't think I had one on my in the pictures, but I had one for it. It looks like swiss cheese though... I had to cut the bottom so it wouldn't hit the chassis, and I had to cut around the pinion gear and on the other side so the motor wires could pass through.
10.19.2006, 05:53 PM
not planning on running next to it when it's a doing a 35mph+...
10.19.2006, 09:55 PM
I run my transmission backwards and no cover to help with cooling. Running 32pitch gears and no damage
10.20.2006, 01:01 AM
That is intresting I figured the would get torn up. I also wondered about wires getting caught but a zip tie can keep that in check. I would still like to get a cover on there. But first things first I need to get the truck.
10.21.2006, 11:36 AM
I have caught a few wires but i use servo tape to secure wires now
10.21.2006, 01:38 PM
I prefer the 'minimalist' look with a touch of safety :020:
10.21.2006, 01:39 PM
We call it...
Zen gearcover..
10.22.2006, 07:11 PM
Better then nothing. I suppose when I build my G2R I'll try it with out. If everyone else thinks it's fine.
KillaHurtz
10.23.2006, 11:32 AM
I run a reversed maxx tranny on my ERevo and have a gear cover as not to have battery wires get sucked into the gears. I used a stock emaxx one, just trimmed the bottom a bit and used ~3mm of fuel tubing as spacers to clear the spur and pinion. Had one experience of batt wires into the gears on the Emaxx I care not repeat. :)
