Hey guys,
I've got a 10lb. E-Maxx 9L/9920 combo right now geared 66/20 on 14cells. The NiMh's just took a dump on me the other day. I would like to go to a 5s with this setup but think that may be a bit much for it. If so, I would like to get a new motor that can handle a 6s .
What is a recomended motor that can handle a 6s with my current gearing & 9920 controller. It will actually be two 3s packs.
Thanks.
I would like to keep my current controller (9920) and gearing (66/20), so what would be recomended for that?
Also, I am currnetly doing 46mph with this setup (9L/9920 on 14cells) and wouldn't mind a bit more speed.
Thanks.
Just pick a motor that would spin at the same speed on 6s as the 9L did on 14 cells. But be careful, the larger cans spinning at the same RPM will draw alot more current. Probably more than the 9920 will take.
A 12L on 6s would give aproximately the same performance as the 9L on 14 cells. Finding a 12L may be a challenge though. :eek: Not sure If I have ever seen one.
Another thing. If you go Lipo on the 9920, make sure you get a low voltage cut off for it.
This is kind of foolish though IMO. If you are buying a new motor, get the larger can XL motor like a 10xl (as others sugested) and geaar it for the speed you want. It will be a much cooler running more stable system in the long run.
to make it...
or break it...
Ok, so I'm flexible with the gearing, but not the controller. And you meen to tell me that I'm the only one to ever buy a car to match the shirt I was wearing that day? Truely I can't be alone on this?
It's looking like 9XL and 10XL seem to be the choice for the 6s?
Can I ask what exactly is your plans for this? Just speed runs. You going to bash it. I bashed a 9xl on a heavier maxx with no probs. The heat stayed good to. Neweuser has the motor now. I tried a 1512 2.5d on 6s. It was pretty crazy. Got a little warm though.
Rc-Monster Buy here
