Mugen MBX5 PROSPEC Brushless Adapter
GriffinRU
Mugen MBX5 PROSPEC Brushless Adapter - 11.07.2005, 07:24 PM
Received the first batch of brushless adapters for Mugen MBX5 PROSPEC buggy.
Details on buggy here
Artur
coolhandcountry
coolhandcountry's Avatar
11.07.2005, 08:31 PM
Hey will this work on a ofna mbx
Peace!
Country
Help support the
Rc-Monster
Buy here
GriffinRU
11.07.2005, 08:42 PM
I don't know.
If you tell me dimensions, then I can check.
Artur
coolhandcountry
11.07.2005, 08:46 PM
well accually don't worry about it. I don't want to mount my motor to the side. Get in way of my batteries. I like to have a top mount though. It would look good on buggy and truck. What kind of measurement do you need
Peace!
Country
Help support the
Rc-Monster
Buy here
Dafni
Dafni's Avatar
11.08.2005, 03:20 AM
Nice product! And nice timing, too!!
This thing will put my motor closer to the spur.
One of those things has my name on it! Yay! Can't wait to get it!
camel_rc
11.10.2005, 08:52 PM
Will it work in a MBX4?
Papa
Papa's Avatar
11.10.2005, 09:06 PM
Can some one explain to me the brake situation with these buggys that have a center dIff. I do not understand. besides the MOtor mount etc... what do you need to do to the gear/diff?
coolhandcountry
11.10.2005, 09:41 PM
I not quite sure on the question papa. You need to get the metal gear off and a plastic one on. As far as brakes. Just use the motor.
Peace!
Country
Help support the
Rc-Monster
Buy here
Papa
Papa's Avatar
11.10.2005, 09:44 PM
Maybe I am crazy! I was under the impression that the mechanical brake was still needed. It came to mind when I saw the pic above with the brakes in it? I switching out the gear a challenge?
coolhandcountry
11.10.2005, 10:03 PM
not on the ofna buggies where the ofna 51 tooth is a direct bolt. Others are a little more. Like making the adapter. I have not ran my buggy yet papa. I not sure what to expect as far as brakes. The center diff has oil in it so may have to get that right for braking to.
Peace!
Country
Help support the
Rc-Monster
Buy here
Papa
Papa's Avatar
11.10.2005, 10:05 PM
Sounds Like My CRT Conversion should work out. Now if I could just find a quality motor mount?
GriffinRU
11.10.2005, 10:22 PM
I do not know about MBX4, but if you can compare diff. housing from MBX5 then you will get an answer.
As for brakes, with center diff, you need to use original disk brakes or combo. In my case, due to the fact that motor is too close to the diff, I am utilizing front disk barke and rear electric motor brake. Just electric wont do the job, unless you make your center diff. very tight.
Artur
P.S. I make this pinion from original mugen pinion
rchippie
rchippie's Avatar
11.11.2005, 11:55 AM
griffen very nice work, that motor mount looks industrutable.
REAL MEN RUN BRUSHLESS
GriffinRU
11.11.2005, 09:56 PM
Thank you, we will see how it works.
That is how it looks with Shultze 18.97 / Feigao 9L / 12 I3800
Artur
P.S. Only 5 adapters left...
MetalMan
MetalMan's Avatar
11.11.2005, 10:45 PM
That's an interesting way to mount the batteries. How's the COG of it? The motor looks pretty low, which is good. Which motor is that?
