01.11.2007, 05:11 AM
Well, the 1950 is going to have more torque. So you would benifit from it if you had a heavier truck. It will use up more power though, naturally. But you may end up having the same because you may be giving less throttle for the same speed. It really depends.
I guess the comparison would be a 4.0L V8 vs a 5.0L V10. V10 would be more powerful and use up more gas, but you can get the same output as the V8 with only 4/5's the throttle amount (theoretically).
I think you would be fine with a 1940, but I'd wait for responses for the true brushless gurus.
6 cell lipo is pretty hefty. If you haven't go your packs, I'd suggest 5S... (2S on motor side, 3S on non-motor side).
