bk help
rampingray
bk help - 05.02.2007, 07:30 PM
i got a emaxx second hand with a bk warrior esc and i tried to program it but i plug it in like the sticky says but i don't hear a beep then one time it beeped but the was no second beep. what up?
t/e ext chassis bk warrior 7018 with 9xl motor
MetalMan
MetalMan's Avatar
05.02.2007, 07:40 PM
Have you tried reversing the throttle channel? Have you tried changing the endpoints and throttle trim?
rampingray
05.02.2007, 07:43 PM
well does that have anything to do with the motor not beeping?
i can't adjust end point but i can reverse it
MetalMan
MetalMan's Avatar
05.02.2007, 09:12 PM
If the Warrior isn't getting the right signal (could happen if the channel is reversed) then it won't program.
Serum
Serum's Avatar
05.03.2007, 02:25 AM
Yep, i had the same 'problem' with one of my 9920's.
The set the throttle offset to 0 percent, and try it with the reversed throttle channel.
