cutting flatspot help.....
maxxdude1234
maxxdude1234's Avatar
cutting flatspot help..... - 06.11.2005, 07:09 AM
I've got a lehner Basic XL motor. Could you please tell me, is it really neccessary to cut a flatspot, the pinion seems to stick on the spindle quite well anyway. My problem is I don't have a dremel, I've tried to file the shaft, but because the lehner shafts are hardened steel it doesn't work.....any help would be welcome....
820maxx
06.11.2005, 08:20 AM
yes 99.9% of the time u need a flat spot go to the hardware store and get a grinding stone 4 a drill less than 4 bucks and start looking 4 a good price on a dremel
Re~Mix
ĄGo Baby Go!
Re~Mix's Avatar
06.11.2005, 10:34 AM
There is no need for the flat spot, I have had zero problems with the pinion coming loose thus far.
RC18T FT - Quark Castle Creations Airtronics IB
  Send a message via AIM to Re~Mix
RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
06.11.2005, 11:36 AM
If the set screw is big enough to allow ample torque, the flat spot isn't necessary.
maxxdude1234
06.11.2005, 02:45 PM
I have roughened up the shaft slightly with some sandpapers. Gonna use a bit of loctite (blue stuff), hopefully should be fine. Thanks for the help guys. I'll report on how it performs.
Serum
Serum's Avatar
06.11.2005, 06:40 PM
Don't glue the pinion on the shaft.. It can be a pita to get it off, when you dropped too much LT on it..
maxxdude1234
06.12.2005, 04:41 AM
That's happened to me once already.....got a 16t pinion permenently fixed on one of my titans. I meant just glueing the grub screw to the pinion. Thanks for the help though
maxxdude1234
06.12.2005, 05:14 PM
well, I tried numerous times, but it seemed no matter what I did the pinion gear kept coming loose! I'm using a robinson pinion (the one's mike sells) - anyone know why this is happening. Or should I just give in and make a flatspot. If so, is this the kind of thing I should be using? http://cgi.ebay.co.uk/ws/eBayISAPI.d...980323021&rd=1
The only thing I'm slightly concerned about is, brushless motors don't offer much resistance (basically none), so won't the motor spindle just spin around with the grinding stone...?
again thanks for your help guys! :)
Re~Mix
ĄGo Baby Go!
Re~Mix's Avatar
06.12.2005, 06:02 PM
Thats really odd, I haven't even used loctite, and I'm running robinson pinions also and they stick just fine, I haven't even noticed a difference between my brushed ones with flat spots. Are you using a hex tool to tighten that thing down or just the flimsy L looking tool?
rchippie
rchippie's Avatar
06.12.2005, 06:49 PM
The best way to put a flat spot on the shaft in my opinion is to take a pair of needel nose pliers put a peice of a rag around the shaft against the end of the can grip it with the pliers. Then take your dremal and make your flat spot. The flat spot only needs to be about 1/16 -1/8 wide and about half the lentgh of the shaft.
REAL MEN RUN BRUSHLESS
RC-Monster Mike
Site Owner
06.12.2005, 06:59 PM
that's how I do it, too.
rchippie
rchippie's Avatar
06.12.2005, 07:05 PM
GREAT MINDS THINK A LIKE:eek:
RC-Monster Mike
Site Owner
06.12.2005, 07:14 PM
scoobie doobie
06.13.2005, 03:20 AM
I stripped the set screw on a pinion cause I put a little too much muscle into it...I had to cut it off....with a Dremel. Dont know where I would be without my trusty Dremel...you dont have to get a Dremel brand either, you can get cheap rotary tools almost anywhere now...
I live with fear everyday....Sometimes she lets me race.
Serum
Serum's Avatar
06.13.2005, 06:46 AM
stripped thread or a stripped head?
