RC-Monster Parking Attendant
Cutting Lexan -
06.27.2007, 02:11 AM
What are some diferent ways to cut Lexan without using special tools?
Im making the esc and battery trays for my revo, using 3/16" lexan, a sharp knife and the score/snap method. Ive made 3 cuts that took more effort than I thought would it would take. Ive seen lexan knives in the hardware store. would they make the task any easier?
06.27.2007, 04:05 AM
get lexan scissors. u can get straight or curved and they cost about $10 and cut lexan like butter
Radek
V4 D8 - RX8, XERUN 4168SD
*EX-10 Eurus*
06.27.2007, 09:35 AM
I've never had trouble with the score-and-break method. I score each side twice to make sure the score is deep enough, put the excess piece over a flat corner, clamp it down, and snap it off. Every once in a while, there might be an imperfection that I'll touch up with a dremel, but I'm kinda anal about having straight edges and perfectly rounded corners...
@Wallot: Can lexan scissors cut thicker stuff, like 1/8" +?? Are you thinking body lexan scissors?
06.27.2007, 11:42 AM
how thick are we talking in mm around 5??
i got some 6mm plastic that im using for a servo mount and atm it keeps melting when i go to cut it, so any advice will be much appreciated here :027:
06.27.2007, 11:53 AM
i like to use a durbro lexan sizzors. for just 12 bucks at your lhs you get the sizzors and a body reamer. these are good but for small indintations they are hard to cut. yesterday i used a dremal to cut out my body. very time consuming but the result was a perfect hole in the back of my 18t body.
Not lexan bodys. Lexan sheets. Like plexiglass.
Originally Posted by BrianG
. . .I score each side twice to make sure the score is deep enough, put the excess piece over a flat corner, clamp it down, and snap it off. . .
I thinks thats the problem. I dont have a workbench so im doing all this on top of a wood board on my living room floor:p. Cant wait to move. I havent been scoring both sides though.
i got some 6mm plastic that im using for a servo mount and atm it keeps melting when i go to cut it, so any advice will be much appreciated here .
4mm exactly. Are you using a saw? I read that your suposed to run water over the blade.
06.27.2007, 12:00 PM
sorry man just realized it was thick lexan not the lexan the body's are made from. in this case use the scoring method, scroll saw, or a dermal with cutting wheel.
06.27.2007, 12:02 PM
im gunna try the snapping method :032: wish me luck
ya it defo needs water or something, it just starts melting, problem is trying to set that up lol no idea how to do tht... o well only straight cuts for me now so hopefully it will be ok
what kinda knife you all using??
06.27.2007, 12:20 PM
well I use lexan body scissors for cutting anything plastic I need and some stuff is 3mm (about 1/8"). for thicker material i would try scissors for metal.
Radek
*EX-10 Eurus*
Nitro PWNS > Electric??? Really? Wanna race?
06.27.2007, 10:10 PM
For my revo battery mounts I used about 3/16" plastic cut by my dremel with cutoff discs. I then rounded out the edges with a grinder.
BL Lipo RC18 - Mamba 6800, Apogee 3s
BL Revo Project - MM, 8XL, 12 cells to start
E-Maxx - 650's, EVX, 12 cells
06.27.2007, 11:13 PM
If using a saw, you have to use a serrated blade at low speed if you don't want to melt the plastic. Also, take small "bites" and back off to let the plastic cool. You could also try a miterbox, but the score and snap method seems to work the best for me and doesn't require a lot of work - just a sharp knife...
06.27.2007, 11:24 PM
I think i might try that. Edges with a bullnosed finish would be nice.
06.27.2007, 11:28 PM
Yeah, here is mine as of now:
06.28.2007, 12:19 AM
For that thickness i use my table or ban saw, with a blade made for cutting plastic. A router works very well also.
06.28.2007, 12:39 AM
I try to stay away from power tools when cutting plastic. I think it's more of a PITA than it's worth. If you don't want to use the score a snap method, try a hacksaw with a fine blade.
