y harness/batts
Richard6908
Richard6908's Avatar
y harness/batts - 07.01.2005, 11:56 AM
i got a 6 cell reedy 3300 and a venom 3300 6 cell with the feigo 8s and mgm 80 could i hook up a y harness and run them two batterys at once.
  Send a message via AIM to Richard6908
RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
07.01.2005, 12:21 PM
You could, but the performance of these batteries are different(Reddy batts are better quality). The better battery will be forced to make up the difference of the other pack. Are you thinking parallel or series?
Richard6908
07.01.2005, 12:41 PM
series
Rtsbasic
RC-Monster England!
Rtsbasic's Avatar
07.01.2005, 12:57 PM
With an 8s you might destroy the motor if you put them in series (so total 12 cells 14.4v. You could run them in parallel and get a lot more runtime/more torque bceause more amps..but in series the motor will (with no load) come to about 63K. With a load your still looking at over 50k which while insanely powerful could destroy the motor. Mike would be best to say on that (if you brought it from him then you'll know where you stand with warranty if you put 12 cells on).
Serum
Serum's Avatar
07.01.2005, 06:32 PM
i think its not only the motor that will start smelling bad..
RC-Monster Mike
Site Owner
07.01.2005, 07:35 PM
Ive run an 8s on 12 cells before. It can handle it. You would need s serious controller if tyou want to gear it up, though. The 8s on 12 cells is pretty rediculous power.
tonka truck
tonka truck's Avatar
07.01.2005, 11:34 PM
I just read this thread and I am a bit confused.
Rtsbasic, you were considering to use NiMh/ Nicad in parallel. I was under the impression that you could only use Lipoly packs in a ?S?P config....so does it mean that you can do a parallel config with nimh packs? This config appears to be something that is not widely published.
Serum
Serum's Avatar
07.02.2005, 01:49 AM
All in the name of science........ ;)
