Storbe spur gears options?
Hickoryhead
RC Wanna BE
Hickoryhead's Avatar
Storbe spur gears options? - 01.02.2008, 07:48 AM
Does any one run a different size spur on their strobe besides the Ofna 51 tooth? Just wondering if there is other gearing options I can use beside only changing the pinion.
NECESSITY IS THE MOTHER OF INVENTION
Emaxx Tranny slipper modification (Strobe like)
http://www.rc-monster.com/forum/showthread.php?t=9341
wallot
wallot's Avatar
01.02.2008, 07:52 AM
You can buy 65T spur for Ofna monster pirate that works after little bit of dremeling - holes are ok but there is some material (the ring) around holes that needs to be removed for the plate to fit
http://www3.towerhobbies.com/cgi-bin...?&I=LXABJ0&P=7
Radek
V4 D8 - RX8, XERUN 4168SD
*EX-10 Eurus*
Hickoryhead
RC Wanna BE
01.02.2008, 08:03 AM
I am trying to stay with a Mod 1 gearing. That 65 looks like a 32 pitch but it could just be the picture.
Patrick
Patrick's Avatar
01.02.2008, 08:04 AM
Yeah, I've used that 65t spur as well. It works ok after a few minutes with the dremel.
Because it's so big you might have to drill another hole in the standard motor mount plate or extend the adjustment slot a bit depending on the pinion you use.
Patrick
Patrick's Avatar
It's mod1 pitch....it's a big spur.
