Question about mounting Neu
Nautilus
Question about mounting Neu - 02.09.2008, 10:01 PM
So I go to mount my Neu 1515 motor to my new Emaxx and it turns out the mounting holes on the motor are not spaced far enough apart to get the 2 screws in at the same time. The motor holes on the stock motor plate are too far apart for the Neu.
I imagine people are not using just 1 screw to mount the motor, so what's up? Did I buy the wrong motor? (I did buy it from a boat place).
ssspconcepts
ssspconcepts's Avatar
02.09.2008, 10:21 PM
Not sure I understand...I have two Emaxx trucks with Neu 1515 motors and they work fine with the stock motor plate? Sounds like your Neu may have a propeller (for aircraft) gearbox attached...or they did not send you a 1515 series motor....but even the 1509 and 1521 series should fit?????
ssspconcepts
02.09.2008, 10:22 PM
Post some pics of your motor and we can resolve this quickly....
Cowboy
02.09.2008, 10:53 PM
You have an older motor. The hole spacing was closer together on the older ones. I have one like that too. I had to make my own mount. RCPD offered to make me a mount but I didn't want to wait.
ssspconcepts
02.09.2008, 10:54 PM
Please post some pics so we can say for sure.
Nautilus
02.09.2008, 11:30 PM
This has got to be it. I guess I will try dremeling the plate and if that doesn't work I will have to get a custom mount.
