1/8 scale buggy weight..just curious on weight after conversion
1/8 scale buggy weight..just curious on weight after conversion - 04.29.2008, 12:17 PM
Just curious on everyone's buggy weight after BL conversion...mine is a tad over 9lbs. using a mm esc, 9xl, cc bec, mech. brakes, and a Elite 25c 4s li-po, RCM motor mount and custom AL top plate, and also custom RCM battery box
04.29.2008, 12:18 PM
Mine's around 10lbs. Neu 1512, 4s 8Ah, Quark 125...
Happywing
04.29.2008, 12:36 PM
Mugen MBX5 ProSpec
Neu 1512 2D/F with MM/BEC
Lightweight Chassis
Stock (non-ProSpec) shock towers and braces
Ti Pivot Balls
All CF top plates
Just under 8lbs with two 2s2p 5k MaxAmps
8Lbs 4oz with two 2s4p 8k Thunder Power ProLite
bdebde
That's All Folks!
bdebde's Avatar
04.29.2008, 01:13 PM
Some heavy buggies there.
here's mine:
Mayhem Pro
MM, Lehner 1930/8, Nue 4300 4s lipo
CF top plates, Ti hinge pins/turnbuckles
7.6 lbs
04.29.2008, 01:37 PM
My hyper 8 weighs 7.6lbs with the batteries, and 6.8 without.
Here is the info about it: http://www.rc-monster.com/forum/showthread.php?t=10857
Hey Brian, you need to pick up a pair of trakpower packs, you could lose some weight that way!
cmcclive
04.29.2008, 01:47 PM
I asked this questions a few months ago in the buggy forum.
But here is my info anyhow
MP777 SP2
Novak HV-Maxx ESC and HV4.5 motor
2 2S 10,000mAh batteries
Weight 9.34 pounds
Shark413
Shark413's Avatar
04.29.2008, 02:27 PM
My latest interation weighs 8lbs 9oz.
Kyosho Kanai III
Neu 1512
Neu Energy 4s1p 5000mah
Mamba Max w/fan and Novak Cap
Front/Rear mechanical brakes (plus extra brake servo).
16mm Big Bore shocks
Steel Robinson Losi wide 47T spur
Carbon Fiber batt tray
Losi 2.0 8ight-E / Losi 2.0 8ight-E/T / jammin SCTRC10 / Slash 4x4 PE
jhautz
jhautz's Avatar
04.29.2008, 04:17 PM
XB8 EC
Hacker 10XL
Tekin R1Pro
PQ 4350mah 5s
No Battery 6.78 lbs
RTR 8.05 lbs
to make it...
or break it...
Silent...But Deadly
SpEEdyBL
"Out of spec" enthusiast
SpEEdyBL's Avatar
04.29.2008, 05:29 PM
7.3-7.6lb rtr depending on the tires and wheels
8ight, novak hv, maxamps 5000 soon to be neu energy 4100s.
Area 52 Ranch Raceway
T.R.C.R.
04.29.2008, 07:51 PM
It seems to me that the model has a lot to do w/ weight..as well as components..I guess that if I am really concerned, it means that i will have to buy a FASTER motor
thanks for the info!
