XTM MMT does it again and resets record.... -
04.30.2008, 04:29 PM
Well did a test pass today on only 10S again with new gearing. 79.7mph and 80.3mph!!!!!! No video yet....so its not offical passes until this weekend if the weather cooperates. Doesn't look good though for the weather.... Those passes were not clean passes either, the truck was skating bad from side to side. Need to work on the suspension a little. I think it should go 81-83mph on a clean pass, then the 12S lipo goes on and cross your finger for 85-90 maybe somewhere in between. Also that is still on the small 1521 motor. My 1527 has not been installed yet.
Serpent S811-E Tekin
Revo 3.3 BL- 1515 1Y
Mugen MBX6 NEU/MMM
Mugen MBX6-T NEU/MMM
Losi LST2.0 MT NEU/MMM
Losi 8T RTR 2.0 NEU/MMM
Losi 8T 2.0 NEU/MMM
Losi 8B-E 2.0 NEU/MMM
04.30.2008, 04:52 PM
Nice work and very intriguing to follow your progress.
Have you considered using a more accurate means of speed detection, maybe a radar/laser gun? I imagine they’re relatively expensive. I’m surprised no “haters” argue the accuracy of your onboard GPS.
04.30.2008, 04:58 PM
I have a bushnell radar gun. The GPS has always been within 0.5-1.0 mph of the radar. The GPS will go to the 0.X decimal where the radar gun does only whole #'s and no decimal. Also I don't like getting people close to the truck at those speeds....a 15-18lbs truck at those speeds would kill someone with any sort of direct hit. A baseball at 80mph does damage and its maybe 1 pound.
My old emaxx runs would be 67.7 on the GPS and 68 on the radar, and many other runs. The radar always reads a little higher then the GPS.
Mugen MBX6 NEU/MMM
Losi 8T 2.0 NEU/MMM
04.30.2008, 05:00 PM
You are shooting for close to 90...  I can't wait to see that vid...good luck
04.30.2008, 05:11 PM
Actually I was only shooting for 80mph with this truck, but it keeps suprising me. I am heading back out again here in a few mins......wish I had a camera man around...lol. Oh well better saved for the weekend..
Mugen MBX6 NEU/MMM
Losi 8T 2.0 NEU/MMM
04.30.2008, 05:18 PM
Even 80mph is very impressive for a truck that size.
04.30.2008, 05:22 PM
I was shocked when it did 76.0mph 2 weeks ago, now I really am excited to see the truck just keep powering through even with more gear...still no problems.
Mugen MBX6 NEU/MMM
Losi 8T 2.0 NEU/MMM
04.30.2008, 08:50 PM
Well did some more testing and it looks like my Turnigy HV might be smoked. Got the white smoke of death but the controller still works, but power dropped big time. Also one of my phaltlines blew completely apart.
Mugen MBX6 NEU/MMM
Losi 8T 2.0 NEU/MMM
Brushless Heavy Weight....
04.30.2008, 09:24 PM
10S and smoking.... :) that's AWESOME!! you must've been pusing 3700+ Watts... I dont' think 12S will be possible if you're smoking that ESC on 10S, 12S would be really killing it.... I just finished modifying my MGT for 12S setup on the KB...
Hook us up with the pics of the burnt ESC..
MGT, ready for 14S 123 or 12S1P Lipo
04.30.2008, 09:50 PM
What I don't get is the controller is still arming and working but it has a power loss. Any ideas??? I can't figure out why its still working after puffing white smoke. Visually I can't see anything wrong with it. Maybe some of the Fet's smoked??
Mugen MBX6 NEU/MMM
Losi 8T 2.0 NEU/MMM
04.30.2008, 10:36 PM
I'm selling one of my Jeti Spin200 if you're interested (All you need is the program box). I've seen 4760 watts with my 1521/1Y on 10S and I ran the truck for 9 minutes. I had to change the diff internal gears right after the run. Were your Phatlines taped? I blew mine as I could only find them pre mounted at the time, but when they blew my truck was taking flight  .
04.30.2008, 09:37 PM
No pack left for that dewalt drill in the background?????? hehehe
04.30.2008, 09:48 PM
Jzemaxx... you seem to be pusing that 1521 to the limit... and it's working great.... I can't believe that small motor is able to push that heavy truck to those kinds of speeds.. I guess that's the power of 4-pole motor & high rpms... that's awesome.. I can only image how powerful the 1527 will be...
04.30.2008, 09:53 PM
I would imagine its got to be coming to the end of its power. Cause its staying cool (~108-115) after each pass, but the controller is getting to 185-200 after 1-2 runs. Guess its overgeared. I will probably back down on the gearing which might hurt the speed, but I don't feel like replacing controllers every 2-3 runs. I don't think the voltage is hurting it at all, its just the amp draw must be nearing 200 or so at the top end cause that is went it puffed, puffed...hehe. Leaving the line its great cause I have the soft start enabled.
Mugen MBX6 NEU/MMM
Losi 8T 2.0 NEU/MMM
04.30.2008, 09:54 PM
Also keep in mind the timing is turned to low as well, so more power is still on tap.
Mugen MBX6 NEU/MMM
Losi 8T 2.0 NEU/MMM
Hybrid Mode
