Computer file help
Hickoryhead
RC Wanna BE
Hickoryhead's Avatar
Computer file help - 05.21.2008, 06:40 PM
I have a movie formated in AVI. What format do I need to format it too so I can burn it on a DVD and put it into my DVD player hooked to my TV?
NECESSITY IS THE MOTHER OF INVENTION
Emaxx Tranny slipper modification (Strobe like)
http://www.rc-monster.com/forum/showthread.php?t=9341
kulangflow
Never Fast Enough
kulangflow's Avatar
05.21.2008, 07:25 PM
What software are you using to burn it to DVD?
ClodMaxx
hold my beer... watch this...
ClodMaxx's Avatar
05.21.2008, 08:48 PM
kulangflow brings up a good point. there are a lot of different kinds of software to do what you're asking. it also depends on how your .avi file was encoded - some types of .avi encoding are supported; others aren't.
if you use an mac, you can drag your file into imovie and hit 'export to idvd', then use idvd to animate the menus and burn the dvds. again, if it's encoded a certain way. or, once upon a time, i would use a program for apple called 'compressor', which would output at different selectable qualities, and i would bring the files into DVD Studio Pro to create custom dvd menus...then burn the dvd's from there.
if you want it down and dirty, i believe Roxio Toast can change the format and burn the dvd.
Eflite Blade 400 heli on 3s
tha5150
tha5150's Avatar
05.22.2008, 11:37 AM
simple and easy ( assuming you can "Find" it..
Nero Vision 8.0
burns music, movies, data, etc. if you choose to make an avi or divx or whatever to a DVD format, it will do it for you. PM me if you have problems.
also, check your DVD player compatibility on www.vcdhelp.com and you might be able to burn your Avi to a 800mb data disk and be fine that way too.
bl-is-future
bl-is-future's Avatar
05.22.2008, 11:48 AM
tha5150 gave you the best way. Nero is quick easy and plays on any dvd player i have ever owned.
tha5150
tha5150's Avatar
05.22.2008, 12:02 PM
well, nero burns .inf files to read the .vob files which holds the movies. which is the same as a dvd at the store.. i would check the comparadility first before you do anything. 80% chance, your dvd player will play .avi movie files.
Hickoryhead
RC Wanna BE
05.22.2008, 09:14 PM
I have Nero 7 Ultra but I will look for 8. I just put the files onto a dvd as in drag and drop method. I will try burning them to a dvd. Maybe it will work. I have a phillips DVD player. It has worked with ripped dvd's before.
bl-is-future
05.23.2008, 09:48 AM
nero ultra is different than the vision express. Ultra i believe wont do dvds. Also do the other suggested. Check and see if the dvd player plays avi. The xbox 360 will.
tha5150
tha5150's Avatar
05.23.2008, 09:04 AM
im not sure thats going to work. you can move an avi to a cd using drag and drop. if you are trying to make a dvd with vob files inside the video_ts folder, you need to make sure you select video dvd. there are options there on the left. on the top left, select dvd or cd. then choose the right burning method. this is crucial, all are different.
again, send me an email if you cant figure it out. i do this daily. i have over 800 dvd's or cd's with movies. heh.
