Rustler Vxl Planning
brushlessboy16
brushlessboy16's Avatar
Rustler Vxl Planning - 05.18.2008, 09:36 PM
Hey guys, ive decided to get a Traxxas Rustler Vxl, I had an xl-5 rustler and u could run the thing into a brick wall and it would just bounce. So i plan on getting a 3300mah 3s zippy pack for the truck, is there anything i should know about this setup or truck?
If i want to e really daring ill buy a 12L, and run the mm on 5s in it
Jeezemax(sp)- im coming after your record
05.18.2008, 09:43 PM
On 3s you will need a bigger pack than 3300. You want at least 100 amps cont, and more would be better. If you are going to gear it up you will be drawing some current.
skellyo
skellyo's Avatar
05.18.2008, 09:57 PM
Must have upgrade...aluminum shock caps or replacing the shocks altogether. I've got a couple of these trucks and love them for their ability to take a beating and laugh at you. A little taste of my VXL bashing:
brushlessboy16
05.18.2008, 10:08 PM
Hmm, i will upgrade the battery in the future, but i dont have enuff money, only like 55 bux, the only batt i have now is my 4kmah 5s..dont think the vxl will like that
azjc
05.18.2008, 11:43 PM
if you have a MM esc I would give that a try, I thought on some other posts you had one
05.18.2008, 11:54 PM
That zippy 5000 pack may be too long for the rusty's battery box?!
HaHa, I said box!
azjc
05.18.2008, 11:41 PM
I wouldnt say the rustler is that rugged, I have crashed into curbs and assoted thing sticking out of the ground at less than WOT and broken front end parts, including RPM castor blocks and front bumper, but I agree with Pimp about using a larger battery, I would nt go less than a 5000 mah, you could go with a Zippy or True RC if on a tight budget
http://home.comcast.net/~truerc/read...eady_packs.htm
http://www.hobbycity.com/hobbycity/s...idProduct=6350
brushlessboy16
05.19.2008, 06:25 AM
i dont know how long the battery box is, i know my zippy 5 was 160mm long!!!
also looking at a FlightPower 4250mah 3s
azjc
05.19.2008, 10:32 AM
I had to do some dremeling and drilling to get a True RC 5000
4s to fit in the VXL Rustler compartment and have it secured with zip ties.
the TRue RC packs are 145mm long
dirt101
dirt101's Avatar
05.19.2008, 06:53 AM
replace the rear shock caps with big bore caps, and get rpm rear bearing cariers. after that its battle ready.
bruce750i
bruce750i's Avatar
05.19.2008, 11:22 AM
I ran my VXL Rusty last night FP Evo 3700 3s1p, 10 min of fun w/ three WOT runs geared something around 16/40 mod1. lipo was under 100f, motor 140f. Charged 1500mah back in after run.
I haven't ran the stock 48 pitch for awhile and too lazy to look up the equivalent tooth count, butt 16/40 seams to be on the slower side.
azjc
05.19.2008, 07:56 PM
I run the same gearing in mine and it has done a good job in keeping the wheelies in check
brushlessboy16
05.19.2008, 11:24 AM
How long does it last on a full pack?
05.19.2008, 11:31 AM
Usually what I do for a pack that is too long is I take out the esc plate and cut the small plastic divider out.
brushlessboy16
05.19.2008, 11:29 AM
Could someone find me the maximum dimesions for the rustler battery box?
