MMM Temp without Fan?
DRIFT_BUGGY
DRIFT_BUGGY's Avatar
Question MMM Temp without Fan? - 06.01.2008, 06:22 AM
How many people have recorded the temp of a MMM without a fan? If so, what setup and what temp do you get?
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
lxmuff
lxmuff's Avatar
06.01.2008, 09:48 AM
I took the top of the casing off with the fan on the truggy. After 5 min racing runs with a 1515 1.5D, I was getting up to 155F. I could position the MMM to get better cooling.
killjoyken
RC-Monkey Poo Flinger
killjoyken's Avatar
06.01.2008, 12:39 PM
In my FLM Savage X SS, 8XL, 4s 4900mah pack, 16/48.
I was getting 90-110F with fan working. The fan quit on me and temps rose to 140F.
Edumakated
06.02.2008, 02:11 PM
I had temps after a 15 minute race of 150ish with no fan.
dirt101
dirt101's Avatar
06.02.2008, 03:34 PM
where are you guys taking temps. at on the MMM. seems like it would be kinda hard with that large plastic case.
RBMike
RBMike's Avatar
06.02.2008, 05:51 PM
Where do you get a replacement fan (stock or other)?
Joe Ford
Castle's Chaos Corner
Joe Ford's Avatar
06.02.2008, 10:00 PM
Anyone in need of a replacement fan can give tech support a call. We'll be happy to send a new one out to you. 913-390-6939 and hit 1 for tech support. DO NOT RUN THE CONTROLLER WITHOUT THE FAN ON...IT IS OBVIOUSLY THERE FOR A REASON!!! ;) And I might add it also VOIDS YOUR WARRANTY!
Joe Ford
Product Specialist
finfin
06.02.2008, 10:07 PM
How's mine for international order?
DRIFT_BUGGY
06.02.2008, 11:43 PM
Is it ok to run another fan on top while waiting for the replacement (2 - 3 weeks to Australia)
Will it void the warranty at all by removing the fan from the MMM and running off the RX power or seperate BEC?
Losi 8ight
MMM V1 w/1.20
TP 5S 5000mah
Neu 2.5D/F
tc3_racer_001
tc3_racer_001's Avatar
06.03.2008, 07:19 AM
could you please send 1kg of these to australia? thanks. :)
hyper 8.5 pro SOLD!
Monster Max Still Working...
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
XRAY xt8
MMM
Neu 1512 3D/F
11t pinion
Questions???
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Questions??? - 06.03.2008, 07:48 AM
Just curious. Are the replacement fans of a new MFG/supplier? Or are you sending the same fan as a replacement? If you are using a new supplier can we get that info for future reference? Thank you Mr. Ford.
Joe Ford
Joe Ford's Avatar
06.03.2008, 10:09 AM
Same fans...no shipping 1kg of them to Australia ;) , and ANY running without the fan, separate BEC or not, will void your warranty.
Joe Ford
Product Specialist
Edumakated
06.03.2008, 11:09 AM
Joe:
Castle may want to consider using a fan with a longer wire so it can be powered off the receiver instead of the ESC board. Fan failures seem to be pretty common and caused by either 1) blades hitting the grills of the case or 2) the fan connector breaking off the ESC board.
One mod folks have been doing is adding small spacer on top of the fan or grill to prevent the blades from hitting the grill. Additionally, others are dremmeling out the bottom of the case a hair to prevent the ESC board from hitting the bottom of the case which is what is appearing to cause the fan connector to break.
finfin
06.03.2008, 12:11 PM
so if we open MMM's Esc case out , it means wanranty is void, isn't it?
killjoyken
killjoyken's Avatar
06.03.2008, 02:42 PM
I highly doubt it since you're just removing the sticker and pushing in 8 tabs. Plus, you need to remove the case to access the fan.
I found a fan that may work as a replacement if you don't want to get another from Castle or want to have a backup on hand. It's a Novak fan (those other guys) that measures 30x30x6. I measured the stock fan @ 30x30x7. Both take a 5v input. There's one at my LHS that I'll pick up and test fit to make sure.
And like Joe said, do not run it without a fan. Judging by the temps some of us have seen it's just not a good idea.
Link to the fan:
http://www3.towerhobbies.com/cgi-bin...&I=LXMYH6&P=ML
