Medusa V2s and MMM/MM - Need some advise!
cdis
Medusa V2s and MMM/MM - Need some advise! - 07.05.2008, 11:27 AM
Hi all,
Current B-Revo:
Tekno Electric Conversion
4s2p A123's
16T clutch bell/pinion, 36T spur
MMM
Mech brakes
Feigao 8XL + RCM Heat sink
Stuff I have on hand, not including the gear in the Revo:
MM ESC + CCBEC
RC-Monster pinions 12T, 13T, 14T, 15T
I was actually looking at the new Medusa V2 range of motors as I wanted to upgrade my 8XL. Was just going to buy a 7XL, but then saw that the Medusa's are rated up to 60k RPM!
My current predicament is this, long story short, I have 2 Kyosho Inferno ST-RRs on the way to me now I'm considering converting 1 to electric as I had already ordered a Kyosho motor mount from Mike, to convert my old Inferno ST.
I've only got 1 MMM, but I have a spare MM with CCBEC that was retired when the MMM came along. The Revo ran fine with a MM+CCBEC with the A123 setup, so I can steal the MMM from that, but then what motor do I use in the ST-RR?
I was considering the Medusa MR-036-050-4800V2-5 as it has more than double the KV of my 8XL, until I noticed it was only 50mm. That's tiny! The 8XL is almost 2cm longer lol.
So then I looked at the Medusa MR-036-060-2000V2-5 which is 60mm, but still only 2000kv. Since it can take higher RPM I guess I can gear it up.
Anyway, so my question is, what do people recommend motor wise for the ST-RR, and also which ESC should I use?
-Use the 8XL from Revo
-50-4800KV Medusa
-60-2000KV Medusa
-Feigao 7XL
-Feigao 6XL
I'd like to stay with the 4s2p batteries as the weight isn't too heavy, and no, I can't afford a Neu motor right at this point :( Damn ST-RRs lol. Maybe after I sell some stuff.
Anyway, any thoughts/advise would be greatly appreciated.
thanks :D
07.05.2008, 11:30 AM
Go with the 2000kv Medusa.
07.05.2008, 11:40 AM
I would go with a lower kv motor, and run 7s1p on the MMM. Something like the 1600kv 60mm medusa. High voltage will offset the 1p config, and the lower kv motor will run cooler.
4s2p a123 is just not enough voltage for a heavy vehicle, you current draw will be high, causing heat...
07.05.2008, 11:41 AM
That sounds like a really good idea, IMO.
cdis
07.05.2008, 06:34 PM
Ok what now? I was running 5s1p and 6s1p in the Revo to start off with, and with the 8XL, acceleration was sluggish etc. I posted about it and someone said to try it 2p as the current draw was approaching the edge of the A123's ablitity.
So I tried 2p and the performance was INSANE. 5s2p was really heavy tho, which is why I dropped to 4s2p and geared up. I race the revo and a 5s2p pack on one side made it really unbalanced in the air.
So you're saying, if I were to go to 7s1p A123, that I could use the 1600kv, and I wouldn't have the current draw issues? Speaking weight wise, that's 7cells instead of 8, and any weight saved is great.
I'm a bit lazy tho, and I only have 12 A123 cells. One 7cell pack will not leave me with enough cells to make 2 packs which would make racing rather difficult.
If I were to stay with the current 4s2p setup, would the 60-2000kv handle a truggy? I read a few peeps are using them in their 1/8 buggies with decent performance.
I can just use the 8XL from the Revo, or get a 7XL or something along those lines, if the 60mm Medusa wouldn't hack it.
I could make to 6S packs so I have 2, but I don't really understand how putting more volts into the problem negates the need for more amps lol :D
Finnster
KillaHurtz
Finnster's Avatar
07.05.2008, 06:59 PM
Because power = volts * amps. If power stays even and you up the V, A will drop. You need ~1600W. You can't really go much higher than 70A on the A123s or its too much for the little 2300mah batts. 7 A123s almost gets you there, but I'd almost say 8 on paper, but if people with real world exp w/ 7s1p and say its fine it should be ok.
azjc
Hi all,
Current B-Revo:
4s2p A123's
MMM
Mech brakes
MM ESC + CCBEC
-50-4800KV Medusa
-60-2000KV Medusa
-Feigao 7XL
-Feigao 6XL
thanks :D
you dont want to gear up a higher KV motor, you will lose torque when the motor has higher KV and you need that torque when you gear up
