a Few questions as i wait for my monster
e-rev project
a Few questions as i wait for my monster - 07.14.2008, 05:21 PM
hello all first question for 5mm motor shaft does everyone shave a flat spot into it?
i have
3.3 revo conversion
RCM motor mount
medusa 36-60-2000kv motor
5s1p zippy-h 5000mah batt
talon tires 5.75"
does all this info look correct i remember looking at an 18 tooth pinion before and only getting 40-45mph which seems to be the best target speed and now i get 50-55 which is prob over geared correct?
did i make any mistakes?
Differential Ratio: 2.8461538461538463
Transmission Ratio: 2.111111111111111
Other Ratio: 1
Spur Tooth Count: 38
Pinion Tooth Count: 18
Total Voltage: 18.5
Motor KV: 2000
Tire Diameter (inches): 5.75
Tire Ballooning (inches): .4
Motor Current Draw: 0
Motor coil Ω: 0.006
Spur/Pinion Ratio: 2.11 : 1
Total Ratio: 12.68471 : 1
Tire Circumference (inches): 20.58 inches (522.67 mm)
Total Motor Speed: 37000 RPM
Vehicle Speed: 56.84 mph (91.3 km/h)
Estimated Adjusted Speed: 52 mph (84 km/h) - 8% loss
Effective KV Value: 2000
KT constant: 0.68 oz-in/A
thank you as always
jeff
bruce750i
bruce750i's Avatar
07.14.2008, 06:04 PM
I grind a small flat spot only as wide as grub screw. Throw it in a sandwich baggie and poke the shaft thru the bag then grab your dermal tool(or go by one) with a fine grinding stone and go to town. or you can use a file but that would blow.
e-rev project
07.14.2008, 06:23 PM
good idea with the sandwich bag i didn't think about shrapnel getting in the motor, and of course i have a dremel, everyone should have one
DRIFT_BUGGY
DRIFT_BUGGY's Avatar
07.14.2008, 06:34 PM
I just used a dremel to do mine
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
Takedown
WARNING: May become violent.
Takedown's Avatar
07.14.2008, 06:37 PM
Yep same here.
RIP- Tammy (9/14/08)
e-rev project
07.14.2008, 08:47 PM
just curious if this seems to check out for what i have
3.3 revo conversion
RCM motor mount
talon tires 5.75"
Other Ratio: 1
Total Voltage: 18.5
Motor KV: 2000
Motor coil Ω: 0.006
peace
j
07.14.2008, 08:56 PM
When you did your earlier calcs., did you enter 4s instead of 5s?
azjc
07.15.2008, 03:47 AM
3.3 revo conversion
RCM motor mount
talon tires 5.75"
Other Ratio: 1
Total Voltage: 18.5
Motor KV: 2000
Motor coil Ω: 0.006
peace
j
I have a similar setup in my conversion the same pinion/spur but I have the wide ratio gears in the tranny first gear removed. and locked in 2nd gear, FOC...you will soon see the Talon tires suck I now go between Crimefighter LPR and Badlands on Maximizer Beadlocks...it all depends on what I am doing...and my setup is good for mid 50s @ WOT... the rest of my setup is in my sig
the Medusa 60 can might get hot in a Revo though ...
Larrydino
Larrydino's Avatar
07.18.2008, 12:24 PM
you have a 38t spur gear?...are you sure about that....
azjc
07.18.2008, 12:49 PM
the 3.3 revos come stock with a 40 tooth so 38 is a slight change
e-rev project
07.18.2008, 10:43 PM
i did not know that 40 tooth was stock (bought the truck on ebay), and yes it came to me with a 38t. i can easily buy another gear. would that still be over geared? i looked briefly on the traxxas site and did not find anything bigger than 40t, is there another option. i already have the 18 tooth pinion and was looking for a cheapskate way to lower the speed. i should have double checked Brian g speed calc
e-rev project
i did not know that 40 tooth was stock (bought the truck on ebay), and yes it came to me with a 38t. i can easily buy another gear. would that still be over geared? i looked briefly on the traxxas site and did not find anything bigger than 40t, is there another option? i already have the 18 tooth pinion and was looking for a cheapskate way to lower the speed. i should have double checked Brian g's speed calc
azjc
07.19.2008, 02:36 AM
you could go to a smaller pinion( I believe a 14 tooth is stock with the 3.3) or a 4s lipo if you want lower speed
drkros3
07.19.2008, 03:13 AM
revo's came stock with a 38 not a 40.
