Finally done!
maneba
Finally done! - 07.18.2008, 12:16 PM
Hi.
Finally i've finished to built my revo conversion.
In the first release of my project i've used a VXL system but it died after two weeks for too much KV of the motor in comparison with the weight of my truck.
Now i've installed:
-MM
-Feigao 8XL
-rc-monster motor mount
-7,5 A ubec
-3 30x30 mm brushless fans. The one on the esc is fixed with red silicon (loctite).
-3S 4500 Polyquest battery.
I've an answer for you. I'm going to remove the first-gear and use the monster with only the second gear. What pinion and spur will you use?
big greg
07.18.2008, 04:16 PM
an 8xl on only 3s? not gonna move that good without biulding heat, should go with 4s
07.18.2008, 04:19 PM
a 9xl on 4s would also be better as far as heat goes Welcome to the forums!!!
07.18.2008, 04:20 PM
Nice paint job on the body... Welcome to the forums as well....
07.18.2008, 06:11 PM
Welcome.
Replace the 3s lipo with a 4s, or 2x 2s wired in series. Use the calculator to determine your gearing, aim for about 35-40mph:
http://www.scriptasylum.com/rc_speed/_top_speed.html
Just fill in the boxes.
TDC57
TDC57's Avatar
07.20.2008, 04:28 AM
Great looking Build you have there...
OOOoo yahh Welcome to the team!.. This is great place to spend a few hours on from time to time..
Have a great one and Cool truck..
Nothing!.. Hahahahaaa..
DRIFT_BUGGY
DRIFT_BUGGY's Avatar
07.21.2008, 12:04 AM
Nice, have you run the truck yet?
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
