Whats the white glue for electronic parts call? -
08.01.2008, 08:24 PM
Im looking for that to held down a couple of caps on my modded MM that I did today, im using hobby epoxy temporary but im looking to get some of the white/black glue stuff that they use to held capacitors, resistors, etc. down, not sure what they are call, any help?
I think it is called thermal epoxy. You can find it at Radio Shack. It is white and the tube is v/ small.
Welcome to the fun house...
I think he means the semi-flexible stuff that helps hold the components in, not thermal adhesive/compound. And if so, I don't know. You could probably use a little shoe-goo. It's firm but not hard or soft. And it should take some heat, but don't know how much...
I've waited almost 1 1/2 weeks to get to post in here...but im glad i did, glad to be here. I did the mod base off someone from this forum I forgot who it was. Yes it is the white stuff, semi-flexible as Brian said, such as inside a PC power supply, xbox power supply, so on and so on but I don't know what it is or where to get them. I got some shoe-goo, but im worry that it won't take the heat and fall apart, the caps goes to around 135-140F. I install some bigger caps on my MM replacing the 3 original ones and i made it stick out to the side but im afraid they will break off on a hard run or something, i need to hold them down as hard as i possibly can. Any other suggestions?
silicone? its rubbery but as pointed out, im not sure if it would melt, and it may insulate the heat! but u can get thermal paste (which never sets) and you could add epoxy over the top to seal it in?
hyper 8.5 pro SOLD!
Monster Max Still Working...
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
