motor current question
Sean
AKA Monkey
motor current question - 08.06.2008, 01:42 PM
in the same car geared for the same sort of speed which motor will draw more current a 7XL or a 8L. thats all nice and simple.
cheers
Cars:
Kyosho Lazer ZX-5, 74MPH Pictures
E-hyper-7 Pro UK
EB4 s3, STS28
My Cars and Projects
  Send a message via MSN to Sean
azjc
08.06.2008, 02:39 PM
cheers
the 8L will have to work harder so it will draw more amps
GriffinRU
08.11.2008, 09:37 PM
Always the one with higher Kv.
jhautz
jhautz's Avatar
08.11.2008, 09:43 PM
I would think the length of the motor will play into that as well. Not just the kv.
to make it...
or break it...
Silent...But Deadly
GriffinRU
08.11.2008, 10:00 PM
Just Kv,
Kv parameter depends on motor size and turns
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
08.11.2008, 09:51 PM
Would they really be that far off from each other? I mean, at the same speed, the two would be pulling the same amount of power from the battery to move the truck. Right? The weight differs a bit with the motors, but I don't think that is enough to affect current draw so much.
aqwut
Brushless Heavy Weight....
aqwut's Avatar
08.11.2008, 10:41 PM
well.. depends what kinds of speeds you're talking about....? the KV and Size of the motor both plays a role... if you're geared for 20MPH, they both would be similar... but if you're geared for 40MPH, then the L will definately draw more amps...
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
What's_nitro?
08.11.2008, 10:45 PM
The smaller motor would get hotter with a larger load, that may be where the discrepancy comes from at high speed.
GriffinRU
08.11.2008, 11:58 PM
Power is RPM * Torque
Torque = Current
Kv defines RPM
Motor size defines motor rated power
If you operate motor outside power envelope -> motor would smoke
If you are going to use within power levels then motor with greater Kv would draw more Amps.
azjc
08.12.2008, 03:03 AM
7XL-2382 Kv
8L- 3072 Kv
quite a difference
