My MGM 16018 catch in fire!
david lamontagn
Angry My MGM 16018 catch in fire! - 08.24.2008, 05:59 PM
Play with my e-revo for an hour or more this week-end without any problem.
Today, i've plug the pack and give it a little run, and in about 3 second after niail the trottle, ........... Poufffffff!!!! some white smoke around the revo. So i remove the body to see a beautifull and big, big flame on the controller
I've un-plug the li-po to save it from the fire.
The negatif input lead have boke inside of the board and short on the input capacitor.
I hope that my 2 li-po pack are correct, i've not try to recharge it.
So i nead a new controller. Maybe a MMM or another MGM i don't know.
Jeremy1976
08.24.2008, 06:34 PM
Sorry to hear.
coolrunnings
08.24.2008, 06:44 PM
A smoked mgm is quite rare, can you tell us exactly what set up you were running? How long have you had it? Also look into getting your 160.18 repaired cause that might be cheaper than buying that new esc which could fail real quick.
08.24.2008, 06:49 PM
Smoked MGMs arent that rare, seen a few recently in truth.
Seems like the on-board data recorder on someones 16018 was reading a continuos current of ~150 amps, and spikes of over 300amps, with a neu 1515 1y or 1.5d. Somewhat startling really.
coolrunnings
08.24.2008, 06:57 PM
I meant quite rare compared to others I won't mention.
08.24.2008, 07:20 PM
Heh, no comment...
08.24.2008, 07:24 PM
David, sorry about your MGM. I bought one from Mike ( same as yours) a month or so ago and have run it a few times w/out issues...hopefully it will continue. I run mine w/a 4s and 1512 1YF, if it makes any difference.
azjc
08.24.2008, 09:27 PM
IMO there is a lot of jarring going on with off road trucks especially with speeds approaching 50 mph and all it takes is a loose connection to cause a short.....both the MMM and MGM controllers are good...I dont think buying one brand over another will keep that from happenning in the future. I do like to make mounts that have foam and/or female velcro to help absorb the shock
Countryhick
08.25.2008, 06:54 PM
This is possible with what some of you off-road guys get up to . But I run mine in THIS
and I only run it on a purpose built track. The strange thing in common about these MGM failures is the fact that they run fine one day then let the smoke out the next . In my instance I had driven the car the day before (temps all good) then the next day I had the car on the bench about to have a drive. Plug in the battery (deans plugs) and POOOOF!!! the dreaded white smoke .
Tick tick tick tick tick tick tick.........
david lamontagn
08.25.2008, 07:03 PM
On mine, there was not only smoke, but alot of fire
The negative bare were the black batterie lead connect on have literaly disconect from the 4 PCB and short with one of the capacitor.
The only thing i'am little scared, is my li-po pack. Don't know if the pack is fine after this happen.
I've recharge them, both pack seem to have all the cells at the same voltage, but i've a pack with an internal resistance of 36mohms and other one with 68mohms.
This is 2 identical pack (TP V2 extreme 5000mAh, 3s) and have always been use in same time.......
coolrunnings
08.24.2008, 09:39 PM
Before you buy a new esc call mike and ask him directly what you should buy for maximum reliability and heck you may want to even ask him what he runs.
TruckBasher
TruckBasher's Avatar
08.25.2008, 12:54 AM
Well...to late for that he sold his truck and will stick with his Baja SS...
E-Slayer direct drive to diff
bensf
08.25.2008, 01:07 AM
I think I remember reading that Mike runs MGMs, but don't take my word for it.
83gt
08.25.2008, 07:32 AM
I don't think it's that rare. I smoked my 16018 in pretty much the same fashion. It worked great for several runs, and then released the smoke on plugging in the battery the next day. Strange. It worked for a while after that only on external BEC or RX pack, and then it shot some little flames when the fets went up.
J.
TDC57
TDC57's Avatar
08.25.2008, 12:26 PM
Sorry to hear about your loss David..
For what it's worth, I've got (5) MGM now, two run great, one has no brakes at high speeds and two are out for software upgrades. MGM, MMM, ETC they are all the same, every time we plug them in, we takes the risk..
Still that sucks sir sorry, if you haven’t already, just send it in to MGM, you should have another one in about 4-6 weeks..
Nothing!.. Hahahahaaa..
