Which Capacitor to use?
lwracer
Which Capacitor to use? - 09.02.2008, 05:28 PM
Need to install one on a Mamba Max......is the Novak 2700uf a good choice?
Thanks!
09.02.2008, 05:30 PM
Yes the HV one... I have them on all of mine...
wade7575
09.02.2008, 05:33 PM
I was told by Griffin that the novak one is a 25volt cap and you need 35volt cap that is rated between 2200 to 3300uf.You can get the cap you need from digikey.com
09.02.2008, 05:35 PM
The novak is 25v which is fine for 4s and a little tight for 5s (mine runs ok on 5s) - 35v would give you more headroom but make sure you get a high temp low esr cap
lwracer
09.02.2008, 06:00 PM
Which one? Novak 5685 1800uf 35v or 5684 2700uf 25v...does the uf make a deffernce?
NovakTwo
Senior Strategist
09.02.2008, 06:20 PM
We no longer use individual caps on our BL controllers. We have switched over exclusively to the TransCap modules. We do offer some of the earlier caps here:
Power Capacitors
We discontinued all single caps from distribution; but, the ones above are still available.
Novak Electronics, Inc.
lwracer
09.02.2008, 06:26 PM
I guess I dont understand the 5684 states that it is a Trans cap?
NovakTwo
Senior Strategist
09.02.2008, 07:01 PM
That P/N is the TransCap module for the 2s-4s HV controllers.
lwracer
09.02.2008, 07:40 PM
So I go back to my original question,,,,which capacitor?
NovakTwo
Senior Strategist
09.02.2008, 07:57 PM
How many cells are you running?
lwracer
09.02.2008, 08:11 PM
We are running 4s.....
NovakTwo
Senior Strategist
09.02.2008, 08:58 PM
The 5684 is for 2s to 4s usage.
kevin23
09.02.2008, 09:17 PM
If you need one,I'll have one at the store tom.
5684 is the cap's I'm using I have 2 extra ones
lwracer
09.02.2008, 09:23 PM
Thanks....
Andrew32
09.03.2008, 12:51 AM
thread jacking!~!!!!
hey, say i didnt want to pay $15 for a flipping capacitor, what constitutes as a low ESR?
and close do i need to mount mine?. like...within 3-4 inches?
