Yes but heat can also make the electronics become badly efficent making it stutter too but if your running only on 12 cells for a 8XL it can't be to do with heat.
That is what I have read here in the forums. I don't have a temp sensor, but I could not hold my finger on it for more than a couple of seconds. It also runs well for the first couple of minutes starts cogging, then it stops responding until it cools.
:020:
Do you have a pic of how itis mounted? Have your tried other receivers? Check your wires and stuff as well. Did you try some other batteries? It should not be a heat problem with the setup unless something is not right. But If the cogging can cause heat problems as well.
Rc-Monster Buy here
I believe there was steam coming out of the caps (516K0).
Is that what they do when they cook? Funny thing is that it still works???
I thought it was smoke, but it wasn't. I stopped running it and the steam stopped. Ran it again steam started to come out again.
Hello. I don't have any experience with BL ESC's, but I do with electronics in general and those caps look bad. See how the tops are rounded? That means the electrolyte has expanded. This can be caused by age (usually 5-10 years, sooner if they are run at very close or just over their rated voltage), running a higher voltage than they are rated, or reversing polarity. The "steam" you saw was probably electrolyte gas escaping.
Capacitors are used to either pass a certain range of frequencies, or to smooth out voltage transients for a more constant current and voltage. I don't know of their function in that circuit, but since they are where the battery wires enter, I would guess they are being used to filter out noise entering the battery wires. They are too small to provide the transient function judging by the amperages the controller will require. Either way, they are needed and that is very likely what is causing your problem.
There are two ratings for a cap: voltage and "farads" usually expressed as uF. All I can see in the picture is 516k0, but on the other side, you should see the ratings I'm talking about. Most electronics shops (RadioShack) should carry those if you feel like replacing them - just be sure they are installed correctly. The white stripe denotes the negative lead.
