Upkeep on Teckno Nue 1515???
shizzon
shizzon's Avatar
Upkeep on Teckno Nue 1515??? - 10.20.2008, 12:31 AM
Is there any regular maintenance/upkeep that needs to be performed on the Nue motors, Lube the bearings etc?
Toys:
Slash with VXL
E-revo with MMM/Teckno Nue 1515/1yf running 4s and 5s
Unsullied_Spy
Unsullied_Spy's Avatar
10.20.2008, 01:44 AM
Tekno Neus need no maintenance at all. Keep them under 60k RPM and under 180 degrees (mine always ran around 140) and they should run for years without a problem.
Learn from my mistake though, check your motor screw length before you use it I don't know how far into the motor the screws can go, but I killed mine by using screws that were too long
CRTIM
10.20.2008, 03:50 PM
LOL...this may be a stupid question but before i ruin my new motor i'll ask .....how do you know if the screws are too long ?? ...thanks for the help
bruce750i
bruce750i's Avatar
10.20.2008, 04:51 PM
Originally Posted by CRTIM View Post
LOL...this may be a stupid question but before i ruin my new motor I'll ask .....how do you know if the screws are too long ?? ...thanks for the help
Well, I gently screw them into the motor by hand to feel when they hit the windings inside, Then you can measure the remaining thread length not screwed into motor to see if they are longer then your motor mount is thick, if so they are too long.
I like the threads to stick out about half motor mount thickness or a little less.
Then i Chop the screw with a dermal cutoff wheel about two or three threads short of touching the windings of the mounted motor.
I think the Nue motors have like 5mm of threads.
CRTIM
10.20.2008, 05:50 PM
Thank you sir for the excellent info....i'll go check it out right now
bruce750i
bruce750i's Avatar
10.20.2008, 05:56 PM
Don't call me sir i'm not your dad(and it makes me feel old). Just slap me around and call me Susan.
emaxxnitro
emaxxnitro's Avatar
10.20.2008, 07:50 PM
also most wire strippers have a thead cutting tool built in
look for the 4-40 marking as they are the right size
808E
bdebde
That's All Folks!
bdebde's Avatar
10.20.2008, 09:39 PM
...I think the Nue motors have like 5mm of threads.
That is correct (5mm), at least for the regular Neu's, I would think the Tekno's would be the same.
