Have a Lipo Charger/balancer problem in question
team3six
Just a guy with a box of crayon's
team3six's Avatar
Have a Lipo Charger/balancer problem in question - 12.20.2008, 10:14 PM
It was brought up on another forum about the opperation of most lipo chargers and an LBA10net balancer not working together. So I prepared a couple of diagrams of the way this should be conected in order to achieve charging and balancing at the same time (This can be used with any balancer so its not just limited to the Hyperion model.) Now the Checkpoint charger is an AC/DC ONLY charger therefore you need either a power supply or a battery to power the charger. The Hyperion Charger that I use has an AC/DC use. So I have a Diagram for each of the chargers. The Only other differeance there is, You wont be able to use the link that the hyperion chargers read off the LBA10 balancer to give you a digital update. Now what you need to realize is the general reason that the charger doesnt recognize the battery and gives you an error message is this.
1. connect the charger and power it up, then make the adjustments for the appropraite battery, (so if this is a 2S battery that has a 5000mAh then do so on the charger and make sure the settings are set for Lipo)
2. Plug in the LBA10 into the following ports as described, (except the battery connection and the lipo connection that comes from the balancer. be sure the switch is set to MASTER.)
3. Now before you plug the battery up you have 18 second to do this (not sure why, but it keeps the message from appearing, This means you have 18 second between both of these plugs to the battery)
Connect the battery lipo plug and then connect the battery plug and then hit the MODE/RESET Button and it should detect the amount of cells by lighting up that LED next to the number of cells and the Lipo LED should flash. Now hit charge on your charger and it should be good to go.
Here are the diagrams. Hope that helps to anyone intrested.
It's not just paint! It's an Attitude!
www.team3sixrc.com
JThiessen
JThiessen's Avatar
12.21.2008, 12:54 PM
Nice work - did you airbrush that?!?!
team3six
team3six's Avatar
12.21.2008, 02:44 PM
LOL, no, but I might as well of done it. Believe it or not I did all that on the paint program in Windows. Now I really think I am insane.
www.team3sixrc.com
12.21.2008, 05:21 PM
That must have taken hours.
team3six
team3six's Avatar
12.21.2008, 06:08 PM
Yeah, just a little bit. maybe i should be getting into CAD
www.team3sixrc.com
Andrew32
12.21.2008, 06:42 PM
haha woulda been faster to do it in cad than paint...you could have made it 3d!
and even made a video with comments and rotations and zooms!
got you all rawled up yet?
team3six
team3six's Avatar
12.21.2008, 07:57 PM
Nope! because I still took the time to do it when no one else would.
www.team3sixrc.com
