killed my neu!
emaxxnitro
emaxxnitro's Avatar
killed my neu! - 01.10.2009, 01:30 PM
my 1515 1y died today. man i knew something was wrong when it had absolutely no torque. withen 1 min it was at 210* and it smells. wow even the best motor i managed to kill. this sucks! wonder if neu will look at it. its only 3months old!
808E
emaxxnitro
emaxxnitro's Avatar
01.10.2009, 01:40 PM
i turn the shaft and its hard to turn. i feels like when you touch the motor wires together
and it gets harder to turn. it always ran good untill now. it stinks of burning wire
808E
sikeston34m
sikeston34m's Avatar
01.10.2009, 02:03 PM
Just about every brushless motor will behave this way.
If you are turning it by hand, it's generating a small amount of electricity. When you touch the wires together and turn it, then you short the amount being generated.
emaxxnitro
emaxxnitro's Avatar
01.10.2009, 02:07 PM
i understand that. but im not shorting them . its shorting inside the can.
i can see it. the blue input wire is melted.
808E
emaxxnitro
emaxxnitro's Avatar
01.10.2009, 01:55 PM
sorry for the quality. but what its is. the blue motor winding wire melted as it enters the can.
808E
sleebus.jones
I like chocolate milk
sleebus.jones's Avatar
01.10.2009, 04:02 PM
Look for the macro feature on your camera, most have it. Usually looks like a flower. That will let you get close up shots.
Sorry to hear about your motor, that's a real bummer. :(
emaxxnitro
emaxxnitro's Avatar
01.10.2009, 04:28 PM
yeah thats what i did. its only a 4 mp so its not very good.
808E
Rustler_Racer16
01.12.2009, 12:54 PM
4mp should be plenty. Make sure you press the button half way down and allow the camera to focus. Then push full down and snap the picture. :)
  Send a message via AIM to Rustler_Racer16
01.10.2009, 03:07 PM
Neu has excellent customer service...contact them and they will tell you how long of a turn around you are looking at for replacement. I toasted my 6 month old 1512 1yf and sent it in overnight and had a new one in my hand in 14 days!
01.10.2009, 03:24 PM
Did the insulation actually melt, or did it wear through and cause the wires to short against the can, then the heat caused the surrounding insulation to melt further- thats what Neu will probably look closely at. The burnt wire smell probably means the enamel coating on the wires is toast- motor is probably a rightoff saddly.
emaxxnitro
emaxxnitro's Avatar
01.10.2009, 03:54 PM
yeah it looks to me as the windings are probably shot. the wires are melted (the copper is melted) hope i can get it replaced.
808E
emaxxnitro
emaxxnitro's Avatar
01.12.2009, 01:46 PM
Yeah I tried that anyways I got the ok to send it in
808E
